Review of Clear-Gearz Differential Cover
Well guy's when I changed out my gears a few years ago I bent the stock cover just enough that I couldn't get it to seal up good.
So I bought a Clear-Gearz cover. At the time they were about $100 and I thought, cool, I can check fluid levels, check for water in the oil, etc., all without even crawling under my truck too far. Well it eventually started leaking a little. Not enough to drip but enough to make a mess, then finally I noticed a few drips. I was going to take off the cover and reseal it when I found out why it was leaking. A corner of the cover had broken right next to a bolt. I don't know how this happened but I know that I didn't have the bolts torqued down too tight. Any way. My suggestion is to suck it up and spend the money on something like a Mag-Hytech. I got my for $260 from their website. It has a drain plug, dip stick, it's really strong, and maybe the best thing is that it has an O-ring with it so you don't have to mess with any gasket maker.:banana: Here's a pic of where the Clear-Gearz broke. http://i274.photobucket.com/albums/j...s/DSC00673.jpg Here's some pics of the Mag-Hytech http://i274.photobucket.com/albums/j...s/DSC00737.jpg Drain Plug http://i274.photobucket.com/albums/j...s/DSC00739.jpg Dip Stick http://i274.photobucket.com/albums/j...s/DSC00740.jpg |
your shocks are leaking
Yea I noticed that too!!
Time for some bilsten's(SP?) I guess! |
yah they are worth it!!
Ever write to clear gearz to see what they would say about it?
No, I would think that they might give me a new cover for free but I wouldn't even want to put another one on.
This Mag-Hytec cover is just that much better I don't even want to jack with it. |
i'll say this. my clear gears took several ring gear bolts being dragged through it. still dont leak. you must've clipped something somehow
Looks good its one of the many things to add to the truck but it may be awhile haha :thumbsup:
I don't know if I'd put a plastic cover on my differential in the first place.
why not? have you looked at how many other covers are plastic anymore? what are u gonna do that a steel cover would be better that plastic? not like ur gonna rub anything with it
I definitely like the mag, when it comes time for one I am definitely going to be switching to a mag.
Just curious, but got any pics of what the clear cover looked like right after you installed it? I was just curious to see how much of the gears and diff were actually sitting in the oil.
Sorry I can't find anything.
Just about half of the ring was in oil. A little under actually. |
Originally Posted by PhqChevys
(Post 3823988)
Originally Posted by Klitch
(Post 3823858)
