Planning on bigger tires and I want more power
Ok so I've been looking through threads to find a good answer but nothing is coming back and giving me a confident answer. I found these gears
http://dagostinoracing.com/index.php...ducts_id=14829
i have an 8.8 rear and i am assuming an 8.8 front at well on my 06 stx 4x4. i know these gears are meant for a mustang but i think i read somewhere that spline count doesnt matter when changing ring and pinion. what are your thoughts. also how difficult/realistic would it be to put some sort of locker or limited slip on these gears also how bout putting a limited slip or locker on the front as well. im fairly handy with tools and i have a close friend who was a mech before the marine corps to help but i would like some outside ideas.
i have the 4.6 and planning on 35's thanks for the input i did not know that i needed a reverse rotation for the front. pretty interesting. i had read somewhere that the spline count didnt matter when changing the ring and pinion only when changing the carrier. is that correct.
Correct. When people refer to spline count they are talking about axle shaft splines which have nothing to do with the ring and pinion. If you change the carrier you have to make sure the side gears have the right spline count or get axle shafts to match.
Motive Performance Plus 4.56 Gears for 8.8" Front
Item #: T60009
Manufacturer Info: Motive F888456IFS
Market Price: $231.99 - You Save 9% ($22.00)
Product Description
To get the best performance gear ratio out of your Ford Truck, you have to install Motive Performance Plus Gears. Motive Performance Plus Gears are crafted from extra strong race quality alloy and should last a lifetime. Motive does not have a bad reputation for “gear whine” so you can still enjoy your ride, while having the ratio of power you enjoy.
It is highly recommended that you get a Master Bearing Kit or just an Installation Kit if you are installing on a truck with over 60k miles. Shop installation costs will vary.
Specifications
* Fitment:
* 8.8" Ford Front
* Year Range:
* F150: 1997+
* Gear Ratio:
* 4.56
Our price: $209.99
Availability: Usually ships the next business day.
