4x4 Problems
I have a 2004 XLT F-150. Just a few months ago, my 4 wheel drive has been acting up.
When I go to switch it into 4-hi.....it clicks like it went in, but then when I hit the gas to go, all I hear is a clicking noise, like it didnt fully ingage? When I switch it back to 2 wheel drive, it stops? For some reason, its not engaging? Does anyone know why? Has anyone else had this problem?? Thanks for any help! |
I am have the exact same problem im not sure whats wrong either?
New body style 04s have vacuum operated front hubs. When vacuum is applied, they are "unlocked". With no vacuum, they are "locked". Sounds like you either have a vacuum problem, or a physical issue with one of the IWE hubs. Neither is uncommon. Each hub has two vacuum lines at it. The bigger one is the vacuum supply. Other is the vent. If you apply a vacuum pump to the big side at each hub, they should hold a vacuum. If not, then the hub is bad. The ratcheting noise you hear is the hub not staying engaged. I have seen it be from broken hoses, faulty hubs, solenoids, and even a reservoir that was blown out (it is behind the battery).
So it is going to be trail and error until I figure it out? Could be any one of those
Usually when I attempt to put it in 4-hi......it clicks....but when I take it out and try to put it back in again....it usually goes in the second time hmm....sounds like its going to be lots of fun! |
Originally Posted by Green_o17
(Post 3596642)
I called my local Ford dealer...they told me that I cant get a solenoid with the sheild on it? Since my truck is a 04?
Now, I have developed at rattling noise when I am driving around in 2wd.....when im on the gas, it rattles, when i let off, it stops...... Sometimes, I switch it to 4hi.....then back to 2wd......it stops for a while? Anyone else have this problem?? What should I do/start with? Thanks |
So....I finally got the new Solenoid with the Shield.....installed it, and I still have the nosie
This was on a Tuesday.....I took it for a 30 mile drive, and the nosie started. So I stoped, put it in 4hi, then back to 2wd...the nosie stoped and I havent heard it in 3 days now?? I dont understand?? What I dont understand is why it would only do it once in a while?? It really makes no sense? I might just take the vaccum lines out and replace all of it, just to make sure there isnt something wrong with them...but then I dont know what else to do?? With all the troubles with this system, Ford should be doing something about it.....there are tons of people with the same problem? What did you guys do to fix this problem? |
(Post 3643764)
This was on a Tuesday.....I took it for a 30 mile drive, and the nosie started. So I stoped, put it in 4hi, then back to 2wd...the nosie stoped and I havent heard it in 3 days now?? I dont understand?? What I dont understand is why it would only do it once in a while?? It really makes no sense? I might just take the vaccum lines out and replace all of it, just to make sure there isnt something wrong with them...but then I dont know what else to do?? With all the troubles with this system, Ford should be doing something about it.....there are tons of people with the same problem? What did you guys do to fix this problem? Have you installed spacers on your truck? |
nope...no spacers
