where to get gears cheap
ok well when i get my tax return back i am thinking about getting some new tires and new gears
i have a 99 f150 4.6L 2wd with a 3.08 open rear end i want to maybe put 33s so i was thinking putting like a 3.73 gear or something like that now where would be the best place to get a good limited slip or posi gear set and carrier and all the parts i need?? |
http://www.jegs.com/images/header/homePage_01.gif
http://www.jegs.com/images/photos/30...-4204F288K.jpg M-4204F288K4 - JEGS Ford 8.8'' Ring & Pinion/Differential EZ Kits Representative Image Product images may differ from actual product appearance. Our Ford 8.8'' Ring & Pinion/Differential kits include all necessary components needed to update your factory ratio ring & pinion and to replace your worn out differential. Designed for 28-spline axles. Kits Include: # JEGS Ring & Pinion Gear Set # Ford Racing Traction-Lok Limited-Slip Differential # Richmond Gear Installation Kit # 2-Quarts of Redline 75W90 Gear Oil # 4-Ounces of JEGS Limited Slip Additive http://www.jegs.com/images/photos/50...555-60001K.jpg 60028K - JEGS Ford Ring & Pinion Sets and Kits Representative Image Product images may differ from actual product appearance. JEGS #555-60028K Ford 8.8" Ring & Pinion w/Install Kit 4.56 Ratio 41-9 Teeth JEGS gear sets are made with high-quality grade steel to provide long-lasting use for street, highway, and the occasional race assault. They're manufactured utilizing modern machining and heat treating for added strength and durability for miles of trouble-free service. Marking compound and sealant included, and sets are also available with an install kit. By having the option to buy a JEGS installation kit with the JEGS gear sets, it has never been easier to install a ring and pinion. Each kit includes JEGS: # Pinion and carrier bearings and shims # Pinion nut and seal # Crush sleeve # Cover gasket or RTV # Ring gear bolts # 75w-90 Synthetic Differential Lube (2 quarts) # Limited Slip Additive (4oz bottle) # Thread locker sealant # Marking compound # Installation instructions http://www.jegs.com/images/photos/500/555/555-61263.jpg JEGS #555-61269 # Deluxe Differential Installation KitFord 8.8" Truck # Pinion and carrier shims # Ring gear bolts # Marking compound and brush # Crush sleeve # Pinion seal and nut # Cover gasket or RTV # Timken® pinion & carrier bearings # Timken® axle bearings and seals # Thread locker http://www.jegs.com/images/photos/500/555/555-81655.jpghttp://www.jegs.com/images/photos/50...55-81655_1.jpghttp://www.jegs.com/images/photos/50...55-81655_2.jpg JEGS Ring & Pinion Set Up Tool Kit JEGS universal pinion depth tool properly sets your pinion depth to prevent ring gear whining, premature wear and failure and works with most any differential. Features: # Calibration block that is machined from extruded aluminum and flat-bottom drilled for pinpoint accuracy. It is designed to be held comfortably during use or placed in a vise. # All aluminum components are hard anodized for strength, durability and for a lifetime of use. # Includes a Jegs dial indicator that accurately measures in .001'' increments. # Includes 3 dial indicator extensions for use with most any differential. # Laminated, detailed instructions that won't get ruined by fluids or dirt and won't deteriorate over time. # Has a custom molded case, components are stored securely to prevent damage and protect your investment when not in use. # Made In USA |
those are some decent sets but im kinda wanting to find a set of gears that comes with a carrier for the limited slip because i was told that my current carrier wont work for the limited slip
is this true or not?? |
Originally Posted by squeaky3
(Post 3547206)
Originally Posted by RED4X4
(Post 3547538)
3.73's with 33's is stupid. Get 4.56's or don't get any at all. Yukon gears with a Detroit Tru Trac.
Originally Posted by p3ripperfw
(Post 3553203)
I would have to agree with that...I have 33's and a 5.4l and I have gone from 14-15 mpg to 12 mpg max....thats with 3.73 gears...I was considering going with 4.10's but have read more than one person saying go with 4.56's
Originally Posted by modea2006
(Post 3553218)
i have the 5.4 with 33's and 3.55's and i get 13mph
(Post 3553943)
2wd or 4wd? Mine fluxuates but seems 13 would be the best right now till I get it regeared
(Post 3554076)
4wd with a 4" lift kit
right now at 65 mph I am right at 1800 rpm's Id like to get it up around 2300-2500 rpms because right now mine would get pretty bogged down if I towed anything... |
If your really wanting to save some money maybe try finding an 8.8 or 9.75 with 3.73s and posi in a salvage yard or something.
Youll get around fine with 33s and 3.73s, personally I think 33s with 4.10s or 4.30s is about right though for most people who are running their trucks up and down the road on a daily basis. |
Called 4wheelparts today and asked about 4.56 gears for my truck. guy said it would be crazy to gear it that high and that 4.10 is right where it should be for 33's. Said not to go with 4.56's unless it had 35/37" tires. Said 4.10's would be right back where it was at stock...I asked about 4.30's and he said there was no gear manufactured for these trucks in that gear ratio.
(Post 3555853)
Ford Racing Performance Parts 8.8" RING GEAR AND PINION SETS M-4209-G430M* 4.30:1 http://www.fordracingparts.com/image...4209-g430m.jpg |
IMHO most of the 4wheel parts guys I talk to are idiots
I'm running 35's w/ 4.56 gears and stock limited slip. Right know my edge is sitting at 16.1 mpg's, but I usually average somewhere close to 15.3 mpg. Of course I have a CAI, flowmaster 40, and edge evolution. I still think I should've gone with 4.88's, for a little more take off power, but my calculations said 4.56 was right on the money for stock. And that's with a 4.6 liter and a suspension lift.http://i704.photobucket.com/albums/w...DCFN0001-2.jpg For a two wheel drive 4.6 with 33's, I think the 4.30's would also be right on the money. I say junkyard 8.8 axle out of a 4 wheel drive for a cheap limited slip, then throw your gears on it and set it up, good to go. Probably run in the neighborhood of $800 for everything. My .02, good luck!:thumbsup:
Originally Posted by Fifty150
(Post 3556152)
This should fit right in there:
