Rear End Noise
Rear End Noise
I solved the problem, it was the parking brake drum shoes. Behind the rear disc brakes, there is a parking drum brake. The pads detached from the shoes and were spinning around in the drum making the noise, The drum is part of the back side of the rotor and simlar in design to standard drum brakes. The pads are not riveted, must be bonded. A new set of brake shoes is $25.00. There is an adjuster wheel, again similar to standard drum brakes, that can be accessed through a window on the back side of the hub by removing the rubber plug. Turn the wheel to allow the pads to free up a stuck rotor.
