no driveline section, so i post my question here!
My question is about the drive shaft for the 4x. There is a corigated rubber lining around the shaft that is addapted to the shaft more on one side then the other. What position should that rubber lining be toward the most, the front or the rear? Sorry i dont have a camera right now so i cannot get pictures.
There's a "Powertrain" forum here. That's were this should be posted.
Not sure what your asking ? I'll give it a shot. Under the dust cover is your slip spline. -Driveshaft position is correct from front to back. - BUT! You have to mark these in relation to the pinion gear - They are balanced and need to be re-installed the exact same way. Says this in every service manual I've read.
If it's to late for that , look closely for signs of how she was mated before you removed. - Maybe you'll get lucky. - If not, you could be in for a rough ride later
Oh trust me! The relations were marked with a slight line with a die grinder, when i took it off. I failed to do that on my 87' f250 460ci. I put new lockers in (back in those days) and U joints. Well, i went down a dirt road to test the 4wheel. Wen't into a plain field with about 8 inches of snow and just plowed through it at about 15mph. Jumped back on the dirt road and got to a main tarred road. Never did turn the 4hi off. Going about 50mph down the road, shes makin a harder and harder rattling noise as i accelerate, so i am thinking WTF? 2 miles down the road she starts grinding and grinding and vibrating then TING! Yes, i broke the 4x yoke. How the heak? Don't ask. But i only assumed it was not balanced right. Anyway, the 99 f1 runs and drives smooth in 4 hi and 4 lo. What i was talking about is covered with a rubber boot, that is circled in the pictureabove, acts as a shock. When i pushed it inward toward the opposite end of the shaft, it went inward. Its moveable. I dont know what it does but it works how its connected. I guess i just had to "guess" LOL.
Wish there was a way to grease it without taking it apart. Mine moves so I don't need to. Lucky me
If I did have to tho, I might get me one of these -
I heard of guys using tile nippers on those clamps before, but I haven't seen that style of clamp for sale yet.
that joint is there because the end connected to the transfer case is stationary and the front diff moves up and down with the suspension. when i dropped mine it was rusted solid and had a hell of a time getting it freed up. if you take it down make sure you grease her good.
*JMC, that is the way i have mine so thats good. Thanks for the help, once again!
