Grinding after towing
Howdy all,
I towed a stock trailer with a quarter horse in it over the weekend. Total trip as approx 250 miles. Half way into my trip I started hearing a grinding sound when I would turn. Seems to be more prevalent in a right hand turn. I would also hear it when I started moving from a standstill going straight forward.
I am planning on change the fluid, but after reading some of the posts in here I am concerned that I might have a more serious issue going on. So do I change the fluid and see if that resolves the problem, or do I take it in and have a mechanic look at it?
Thanks,
Craig
Thanks,
Craig
is it a grinding or more of a popping noise. How heavy was the trailer loaded. I wouldn't think this is related to the towing more of just something that broke from stress and the towing just made it show up. IT could a numerous number of things if its a popping I had the same problem when turning right it was my right side axle shaft. Hope this helps
Ill try to help out in every way possible I tow everyday for landscaping so i should be able to figure it out if its like a grinding/shudder on cornering and you have a limited slip your clutch packs could be burnt. I know mine are but I didnt have the money to fix it so I changed the fluid and it helped my shudder.
Any idea what this runs to have fixed?
Thanks again for the replies to this thread.
Craig
It'll cost around what a gear swap will so if you decide to fix the problem you might as well get better gears considering it'll cost about the same. Gear swap w/out a locker/posi/lsd runs anywhere from $500 to $700 per axle. With a locker/posi/lsd it would be around $1000 per axle. If you decide to re-gear make sure you ask around a lot for who is the best gear guy around you because gears are very tedious, time consuming, and **** to change.
Appreciate it.
Craig
Wrong.
If it is indeed the clutch packs it should not cost as much a re-gearing. You can buy $85 rebuild kits for the limited slip and do this yourself at home.
There are plenty of write-ups online about "rebuilding ford limited slips".
You may be throwing your money away if you don't try changing the fluid out first anyway, or correctly diagnosing the problem.
If you decide to re-gear, great. But rebuilding a limited slip should not cost as much as a re-gear.
Wrong.
Craig
i would fix it and keep it. our year i think was the best year for these trucks. any truck that stands up to my abuse is a keeper
buy a kit and do it in the driveway i have before wasnt too bad.
i consider it a learning experience and if you need help pm me
no problem its a pretty straight forward process but a lot of disassembling is required. Set aside at least a day since its your first time. Remember just take your time I am sure you will figure it out my truck has 350000 miles so everything in mine was burnt
