Lockers, Wheels and Tires, And Suspension.
I just perfer lockers (detriot to be exact) but thats me i know alot of people that like spools and enjoy having them.
my truck is a daily driver. and its on the road when wet. When i get something it will be a locker. A spool is a pain on the streets and puts tons of stress on the axles.
Now dont think a locker will be just peachy on the street either, they can bite you in the but also.
Actually my Limited Slip has bit me in the but a few times now.
I will still be able to drive the truck on the pavement with the spool. And it will save me 400 bucks about. Yea I see the detroit locker isnt ALWAYS fully engaged untill it slips then it is, correct me if I am wrong. But thats the only difference. So id rather save 400 bucks than to have a limited slip till it slips then act like a spool.. Correct?
Turning wont be real noticable difference with a spool in the rear will it?
Eh im still deciding..... And for the selectable locker for the front, does a hole need to be drilled into the diff case? for the line/wire or whatever to run out?
turning will be much different with a spool. since the tires are gonna spin the same speed then the backend will want to slide rather than turn. this problem will be magnified in slipery roads.
a locker will allow the tires to spin at 2 different speeds allowing it to turn. and when the lockers are engaged it will work EXACTLY like a spool. Now the locker can still bite you in the butt if you try to throttle though at turn and it locks up and sends your backend around you... i know ive been there. But thats why id have a manual selectable locker.
My buddy has a spool in his Jeep XJ and he wont move the thing out of the driveway if the roads are wet.
im doing some research and i cant seem to find any manual operated lockers. But im reading alot of GOOD reviews of the Richmond Gear Powertrax. Its an automatic locker.
The other GREAT selectable locker that im actually think of putting in mine is the ARB Air locker. you have to have a way to get the air there but its NEVER a bad idea to have a onboard compressor. And this type of locker is push button! ITs more expensive but worth it.
anyway you go you will have to learn how to drive with the locker, and also know how to correct it if you ever have a lock up.
The easiest thing about a spool is that you WILL know that driving around a corner will be squirmy and that in the rain will be dangerous EVERY SINGLE TIME. and you will learn to drive with it.
the catchy thing about a locker is that it could lock up when your not expecting it and cause a bad acident if you dont know how to correct it.
I know im playing both sides here be id rather you make the desicion than me spoon feed you.
