rearend just broke no worning nothing
  #31
Old 07-05-2008, 01:19 PM
jbrew's Avatar
Well, just keep in mind - They may not be designed for that kind of stress, there's NO reason for it. Whether it can take it or not, I guess you found that out - 3 times over.
You might want to think about a couple Ford 9" third members, they will take abuse. I used those without ANY problems w/44" GH's in an 89.
We all live and learn - emphasis on "learn"
  #32
Old 07-05-2008, 03:56 PM
Klitch's Avatar
i dont think downshifting is that hard on the rear end at the mentioned speeds. rather i think its harder on the u-joints and companion flange and the slipyoke.
as far as neutral slamming or whatever their term was, bull****. i personally think that will eat a trans before a set of bolts back there. those bolts are designed for some real good tensile strength for a reason. i do not and will not replace them with grade 8 bolts, i will continue to pay $3.30 a bolt for those particular bolts. i believe they supply grade 8 bolts?
  #33
Old 07-05-2008, 05:00 PM
ssj4shane's Avatar
my last 2 rearend blew out because the power of the motor took out the gears over time... they start wearing and then get weak and chip...
O and the fact there cheap gears
this time was not like the others... this was a installers error or a defective part..
the limited slip/the whole chunk deal... is bent.. i was going to weld it today "ring/limitedslip" but me and my buddy both know that the gears
would be shot by tomarrow... so no point...
My buddys going to lend me a ford 9 to put in so i can get around untell i can
find a 9.75 to rebuild.
And moneys not a problem just i invest my money and i dident think
i would end up spending as much money as i have in the past month.
As for the bolts im not sure if they are grade 8 or higher....
but 5 of the bolts broke... the rest came out befor it broke
O ya and i have a feeling that the bolts were bending back and forth befor they snaped...
stress facter on bolts..... i think it makes sence
  #34
Old 07-05-2008, 06:22 PM
jbrew's Avatar
Yea , you'll prolly be alright with a 9.75 in there. They go even taller 10.? in the 3/4 & 1 tons come to think of it. - Probably for good reason.
  #35
Old 07-05-2008, 06:29 PM
ssj4shane's Avatar
they have lightningz running 600-1000hp with the 9.75 so i dont feel i need to go bigger...
i want to do as less fabbing as i can
plus if i go to a 8 lug i will have to get new rims or spacers and to make my 5x135 go to 8x*** would cost like a grand... the spacers cost alot..
But converting from 8 to 5 might not cost to much....
  #36
Old 07-05-2008, 06:37 PM
jbrew's Avatar
whatever mann , do what you want. I think the 9.75 would be better all around - That's what is speced for the 5.4L. You should put what belongs behind - to handle that torque. But that's to obvious I guess
  #37
Old 07-05-2008, 09:41 PM
Raptor05121's Avatar
Downshifting into 1st at 25 mph? Are you crazy? Heck I downshifted into 1st at 7-8 mph and the engine immediately slows me down to a crawl.
Also, please learn how to spell, I don't want to waste my time trying to figure out what you are saying.
  #38
Old 07-05-2008, 10:06 PM
jbrew's Avatar
I was going to say something about that - figured I was giving him enough hell
  #39
Old 07-05-2008, 10:42 PM
wfin2004's Avatar
I'm hip.
  #40
Old 07-06-2008, 03:29 AM
Klitch's Avatar
uh dont weld carrier to pinion... if you do anything with a welder in the rear regarding the ring gear, you just tack the bolt heads so they have to break welds to back out.
your a step ahead of me, my 8.8 is still kickin so im still running it. go for the 9.75 its pretty similar to a d60 rear.
  #41
Old 07-10-2008, 04:05 PM
ChipB727's Avatar
OMG this is the most painful thread I have ever read!!
  #42
Old 07-10-2008, 04:17 PM
MercedesTech's Avatar
^^^ lol Thats kinda why i just stopped.
Don't worry, if ya try, you can find even better !!
  #43
Old 07-10-2008, 04:40 PM
ssj4shane's Avatar
this thread is funny because i know what happen is not my falt...
i started this to ask a simple question.
What could snap or brake inside the rear end at once..
But then people started saying learn how to spell and saying things like
thats what u get for downshifting...
Auto downshifting will not left you downshift to soon...
manual trans do the same thing...
people dont care
  #44
Old 07-10-2008, 05:26 PM
people dont care
True, what do I know anyway ???
Its not all what your saying, just kinda this thread in general. Not a personal attack bud, by any means. I couldn't care less on spelling and what not.
  #45
Old 07-11-2008, 12:20 AM
ssj4shane's Avatar
All good i get my wiz teeth pulled in the morning...
im mainly happy the 8.8 is gone and i got a 9.75 in there now
Quick Reply: rearend just broke no worning nothing
