does SLIP work in reverse
Old Jun 22, 2000 | 08:32 AM
freemansoft's Avatar
Question does SLIP work in reverse
I have a limited slip on my F150 supercrew. Last night I backed up a gravel road in reverse. A very light tap on the gas had me stuck with a spinning wheel. (I couldn't tell if both were spinning). Does a SLIP work in reverse or only when moving forward?
Old Jun 22, 2000 | 01:40 PM
ford-tough1's Avatar
Post
Yes the limited slip works in reverse. The clutch packs have no way of determining which way you are going. They are engaged. Only when the traction of one tire greatly exceeds traction of the other will it slip(causing you to have one wheel spinning) However you had both wheel on gravel with pretty much equal traction so both tires were spinning. The reason you spin in reverse is because the bed of the truck is light to start off with and then when you gas it, the weight shifts even more to the front. When going forward the weight shifts back on to the wheels.
1997 4x4 5.4 ORP XLT extended cab Dark Toreador red Westin nerf bars tint HARDER THAN A ROCK AND FASTER THAN A HEART BEAT
Old Jun 22, 2000 | 02:11 PM
max mitchell's Avatar
Thumbs up
Forward and Reverse except when it is fried.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
4-wheel disc/ABS,Chestnut/Parchment,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification,Superchip,
Dynomax ultra-flow welded 3" cat-back.
