F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Other Powertrain (https://www.f150online.com/forums/other-powertrain-15/)
-   -   Offroading with 37's question? (https://www.f150online.com/forums/other-powertrain/320916-offroading-37s-question.html)
Titanium15 Feb 12, 2008 10:19 PM
is it bad for my truck to go offroading kinda hard without gears? Cuz im about to be done with my truck and want to go offroading just curious.:banana:
tnsilverfx4 Feb 13, 2008 09:41 AM
You are really going to overwork your engine and transmission.
Do you have 3.73's or 3.55's? 3.73's you might make it out of the bog and back home. 3.55's i wouldnt risk it.
37's are really taking your truck out of its power band with the stock axle setup. It really depends on how hard you are off-roading it. I would be more concerned about getting stuck and bogging down the motor trying to get out.
Take a friend and a recovery strap and post pics
Jordan not Mike Feb 13, 2008 01:34 PM
Dropping down to 4-Low will help a lot.
NoLongerJeepin Feb 13, 2008 02:20 PM
still those 37s are going to put alot of strain on your truck. i would wait for gears then go out. or els you might hafto replace alot more then just gears
chapdog Feb 17, 2008 02:01 AM
ran stock 3.73 gears in my 99 with 35's for 2 years and a 1 1/2 with 38.5's and offroaded everyweekend with out a problem so you should be fine.Just use 4 lo first and second gear overdrive off.Did many mud bogs and sand dune runs with it.did wonderfull in the mud but felt way under powered in the sand.
