f150 7700 series
#107
Front strut assembly
I know this thread has aged a bit, but I'm frustrated and nearly at my wits end. I've been looking high and low for a front strut assembly for my 2005 F 150 7700. Its a pain in the **** to find parts for my truck, but I refuse to give up. Any suggestions would be greatly appreciated.
#108
#110
Heres a Post I made a while back...
I had an F250 LD, same thing as the F150 7700, with the 7 Lugs, It was such a pita to find aftermarket parts for especially Wheels.
Heres a Picture of mine:
Attachment 27963
and some facts about the 250LD/F150 7700
- 7 Lug Rims -
- They have a larger frame then the F150
- Bigger Brakes
- 3:73 rear end from factory
- 4R100 Tranny
- Extra leaf in back
- Larger Torsion bars -
- Heavier towing capacity
- Weigh more -
- Larger rotors, I believe 13.5"
- HD shocks
- power steering cooler
- 4700 lbs rear axle
- HD rad, thicker
- HD alternator
- HD battery
- LT tires standard, load range D
- the tranny is the same as a F250 SD and the F350 SD
- 8,600 lbs towing
- 11,500 lbs GCVWR
- 7,700 lbs payload
Attachment 27963
- 7 Lug Rims -
- Bigger Brakes
- 4R100 Tranny
- Weigh more -
- HD shocks
- HD rad, thicker
- HD alternator
- HD battery
- 8,600 lbs towing
- 11,500 lbs GCVWR
- 7,700 lbs payload
#112
My
That's kinda what I thought, that it was basically a light duty f250 in f150 clothing. I really want to know what gearing the 7700 came with because 3.55's don't cut it for me u need atleast 3.73's to be able to tow decently. How is the 4r100 trans different than the regular f150 trans?
#113
#115
