4X4 Question?
Old 12-27-2006, 07:16 PM
Pete W.'s Avatar
Smile 4X4 Question?
Is it possible for the drivers side front wheel to be engaged and the passenger side not? I have a 2001 F-150, 4.6, Manual Trans. and floor shifter for my 4 wheel drive. My drivers side sounds engaged and the passanger side not. Help!! Pete Could the sound be something else?
Old 12-27-2006, 07:38 PM
kingfish51's Avatar
Not possible on your vehicle. The engagement on your vehicle is at the diff, not the wheels. You don't have hubs on your vehicle, just CV joints.
Old 12-28-2006, 10:05 AM
Pete W.'s Avatar
Then what is the problem?
If the four wheel can't be engaged one side at a time then what can the noise be? Hub bearing or cv joint? Thanks
Old 12-28-2006, 12:02 PM
kingfish51's Avatar
That's a possibility. Is the CV boot torn? If so, it almost certainly has dirt in it, and possibly no grease.
Old 12-28-2006, 01:13 PM
Pete W.'s Avatar
CV Boot
CV boot not torn. Just rotated tires to see if was tire noise. Spun both sides when in the air by hand-drivers side spins harder than passenger side. Looks like the bearing.
Old 12-28-2006, 01:43 PM
kingfish51's Avatar
Also check calipers and brakes to make sure they aren't dragging. I believe the bearing hub on those is a one piece sealed unit. Not sure though.
Old 12-28-2006, 01:48 PM
97_4sixer's Avatar
Kingfish you are correct, the bearing hub is a sealed unit. I had to replace the left one on my 97 F150 4x4.
Old 12-28-2006, 04:37 PM
Pete W.'s Avatar
Brakes are fine.
Thanks guys. Could the sound be anything else but a hub bearing?
Old 12-28-2006, 05:19 PM
kingfish51's Avatar
Just because the boot isn't torn, does not mean it isn't a bad CV joint. Probably best bet is to get it diagnosed somewhere that you trust.
Quick Reply: 4X4 Question?
