F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Other Powertrain (https://www.f150online.com/forums/other-powertrain-15/)
-   -   Vibration on driver's side (https://www.f150online.com/forums/other-powertrain/182828-vibration-drivers-side.html)
Iowa 4X4 Jan 21, 2005 11:31 PM
Any ideas on this problem are much appreciated: I have 1997 F150 4X4 and it has a vibration only on the drivers side in 2 and 4 wd. When engaging the front drive, there is a noticeable 'pop' in the drivers side hub area. All the tires and suspension and cv shafts have been checked. The upper A arms and lower ball joints have been changed in the lasty month along with getting rid of the squeaky pitman arm. It is very loud at highway speed and seems to be louder when entering a curtve turning to the right. Any thoughts out there??
bigbronc Jan 23, 2005 09:03 PM
Do your tires look worn? Could be a tire noise. As for the pop in four wheel drive, your truck uses a system that slides a collar to engage the front axle, which happens to be on the pass side of the front axle. If the noise changes with cornering, I would look at wheel bearings or tires.
Robbie
