Driver auto window
The one touch down is operated by the GEM.
It actually shows as a 3rd position on the switch.
It could be the 3rd set of switch contacts are dirty, or something happened to the one touch down relay in the central junction box.
on the far reaching part, that the Gray wire circuit 995 to the GEM is pinched and not making connection. That is really far reaching.
To test you could take apart the switch cover on the door, and apply power from the light blue/black stripe wire to the gray wire in the connector for the left window switch. This is the ACC delay circuit ( circuit 400 ) that powers the window switches.
The pins are marked as Circuit 400, light blue / black stripe is pin 4, and the one touch down is pin 3, but watch the color codes on the wires, as the illumination pins, and the right front power switch are also in there as well.
Good luck, let us know what happens
