ATTN ALL 98 S-cabs
Without having to go look.....I'm gonna shoot from the hip!
Yep......seat belt has to come off and you also have to remove the hinge for the side window, and then you grab the top have of the panel (over the window area) and pull the panel away from the wall of the cab. Then you do the same thing on the bottom half, there be little plastic "push pin" holding the lower panel on the truck you just take a small standard screwdriver and push the center in about a 1/8", and then the pins will come out.
When you pulling the panels off, pull at a steady pressure, this way you don't stress any of the plastic panels.
Hope this helps!
Let me know how it goes!
Hope this helps!
