ham radio operators
i know at least a couple people on here are. i have some questions on my connex 3300. i was wondering if someone could answer
1) how do u cross referance the freqs with the knob settings? 2) what is the power output for hi/lo. it doesn't have any kits so it should b stock. 3)should i ground the radio to get rid of some of the alt whining? |
Ok, call me stupid. Ham radios. Those are different from your standard FM/AM/LSB CB's? Or is it similar.
I'll bite.
First off you should ground the radio anyway but to help with the alt. noise you will need a good filter. If you cannot find any info online for the radio just put a power meter between the radio and the antenna, this should tell you exactly what its outputting to the antenna. The freq settings are going to need a frequency counter installed between the radio and the antenna so that when you key the radio the actual freq is displayed and then you can reference the dial position. Hespen537, Ham is a step up from CB radio. Same basic idea just a whole lot more you can do both in radio's and high power amps. |
Ok, I know exactly what your talking about.
I guess a way to stop the alt noise, would be to ground it to something but your battery. To the frame or something similar. A frequency display would be beneficial. If your radio doesnt already have one on it. You can cross reference with other radios, as long as their working on the same bands. |
Weird, I replied to this thread this morning but my reply is gone. Anyhow...my suggestion on the alt noise is to run both your power and ground straight to the battery. I would say minimum 12ga, fused of course.
I am curious what you are doing with this rig. This is one of those 10 meter "import" radios, correct? Are you planning to open it up to the 11 meter CB band? |
DrkHrse,
I was thinking the same thing on the import rig. I like your suggestion on running power directly from the battery to, this should help to reduce the amount of electrical interferance the radio picks up. If this is truely an import radio it may display the actual freq. as it is not a true 11 meter or CB radio for you non-ham guys. If that is the case then there is no guess work in knowing what freq. you are on the only thing you need to figure out is what does that freq. mean as far as a CB channel number. I haven't looked in a while but I think you can get the conversion charts online for the CB radio freq's. |
Originally Posted by LegIron
(Post 3522450)
DrkHrse,
I was thinking the same thing on the import rig. I like your suggestion on running power directly from the battery to, this should help to reduce the amount of electrical interferance the radio picks up. If this is truely an import radio it may display the actual freq. as it is not a true 11 meter or CB radio for you non-ham guys. If that is the case then there is no guess work in knowing what freq. you are on the only thing you need to figure out is what does that freq. mean as far as a CB channel number. I haven't looked in a while but I think you can get the conversion charts online for the CB radio freq's. .....but thats just me |
drkhorse is right it is a hf radio but its still thought of as a cb not a ham. the galaxys and other compatible models have built in freq counters but this one doesn't. im looking to find a good deal on a freq counter.
thanks for all the help! tomarrow im going to try and put pics up i really like how i mounted it. |
Originally Posted by gcw
(Post 3522738)
thanks for all the help! tomarrow im going to try and put pics up i really like how i mounted it. Post up those pics though. I would like to see what you came up with. I am in the process of moving my stuff around myself. I had everything mounted where the console bucket used to be but it was not cool to have to look down all the time. I have eliminated a couple of my scanners and am dash mounting everything. Still need to mount my CB back up though. I think I have figured out a way to get it where the lighter is now but am still lacking a dash trim panel I am willing to cut up. Here is my junk so far.... http://img389.imageshack.us/img389/4...nstall2po5.jpg |
http://hotspotcb.com/charts/freqchar33.html
Freq chart for that export radio. As for hi low? Prolly 5 watts low - 10 watts high... As for the whine. your ground is inadequate or you are running power near the alternator.... |
Originally Posted by DrkHrse
(Post 3522892)
http://img389.imageshack.us/img389/4...nstall2po5.jpg This is a sweet setup. That lower radio, how did you do that mount, I would be very interested in one for my IC706-MKII |
Looks good DrkHrse.
Originally Posted by WaWaTuSi
(Post 3523806)
That lower radio, how did you do that mount, I would be very interested in one for my IC706-MKII http://img389.imageshack.us/img389/8...bracketnu8.jpg |
Ill echo what everyone else has said. It would be nearly impossible to use a 3300 on 10 meters as a 3300 uses channals and 10 meters operates between channals, so to speak
thanks for all the advice/help everyone
drkhrse no i dont have my license my wife does and so does 90% of her family:) as for me im a marine scout observer i know the phonic alphabit correct numbers andim working on morese code. i have the clearance to load crypto on hf, uhf and vhf i also work with satcomm, so when i do goto get my own call sign it should be pretty easy. i hate what ch 19 has turned into my dads a trucker ive pretty much grown up in a kenworth and i never rember hearing any cussing, lot lizzards, rambos but maybe i just didnt know but now thats all it is. alot of my buddys on base have cb's and its cool to key up and say hi but if we say much of anything well role to another ch. thats another thing that makes me :mad: anyways ill get some pics up its tore apart from re doing my subs and finishing my center console |
