03 Screw Lariat needs racks to fit around tonneau cover
Old 08-19-2018, 12:24 AM
RickyPwell's Avatar
I have a tonneau cover on my 03 Screw Lariat. I am looking for a rack to carry canoe or kayaks.
Any ideas?
Old 08-25-2018, 01:40 AM
Fifty150's Avatar
https://www.usrack.com/responsive/ra...overs-work.php
The following truck racks will fit trucks with a tonneau cover installed. To view all information for the rack of your choice, click either the image or the name of the rack.
[img]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img]
The Schooner Truck Rack
  • Handsome and functional design is dynamically stable – the weight actually rests on the bedrails not in flimsy stake pockets
  • Extruded aluminum legs, side rails and crossbars are oval-shaped for low drag and noise. Connectors and bases are steel that is first zinc plated and then powder coated. Threaded hardware is stainless steel.
Model Series: 2011-2
From $649.00 delivered
The Galleon Truck Rack
  • This rack is recommended for short bed trucks that need some additional length over the cab to carry long cargo. The overall length of the rack is 8.5 feet as measured from the tailgate. The length of the portion of the rack extending over the cab depends upon how long your truck bed is.
Model Series: 2011-3
From $849.00 delivered
The Turbo Truck Rack
  • This truck rack installs in less than 5 minutes with NO drilling
  • Can be placed and mounted over any door or window opening of the cab.
  • Has a 1.1” crossbar that works with many kayak, canoe and cargo accessories including Malone and Yakima.
Model Series: 2008-T
From $49.00 delivered
The Stake Pocket Truck Rack
  • The Stake Pocket Truck Rack works with tonneaus and carries ladders, lumber, kayaks, canoes, or other cargo weighing up to 500 lbs
  • Mounts or removes in less than 10 minutes without drilling after initial assembly.
  • Removable components each weigh less than 25lbs.
Model Series: 2005-3
From $599.00 delivered
The Extend-A-Truck Rack
  • Extend-a-Truck is designed to carry one end of Canoes, Kayaks, ladders and other long cargo.
  • Adjustable length for bed extension. Reaches back 53” and reaches up 15.5” to 23” above hitch. Red flag included.
  • Works with hard and soft Tonneau covers.
Model Series: 2008-E
From $149.00 delivered
The Adarac Truck Rack
  • Mounts into the stake pockets found in the bedrails of most trucks. The Adarac truck Rack works with tonneaus and carries ladders, lumber, kayaks, canoes, or other cargo weighing up to 500 pounds.
  • Designed originally to work with the Access Tonneau covers sold on our website. Call us about getting a special discount for buying an Adarac truck rack and Access Tonneau cover at the same time.
Model Series: 2010-A
From $549.00 delivered
U.S. Rack™ products are warranted for a period of one year against all structural defects in materials and workmanship provided that they are assembled, installed, and used in accordance with all manufacturer’s specifications and instructions. U.S. Rack cannot warrant the powder-coating which is subject to scratching. See merchandise return policy
Quick Reply: 03 Screw Lariat needs racks to fit around tonneau cover
