2009-2014 Factory Naviation to Factory Non-Nav Swap
Anyone know how difficult it would be to take out the factory navigation in my 2010 F-150 Lariat and swap it for a standard factory radio system? I am wanting to do an iPad install, but I want to retain my climate controls, heated/cooling seats, etc plus be able to see what source I am in, and radio information. I already have the HVAC module for the standard system, as well as the standard radio information display unit, and the compatible steering wheel remote. Is it possible to swap my components out for this? Or would I run into a disaster of wiring issues? I should say, that I would prefer to just use the radio I already have, just without the navigation display and the additional hardware I mentioned above. Any advice? Is this possible? |
For the most part, these manufacturers try to keep all the wiring the same. It saves so much money.
However, the only issue you might run into is if there is any corresponding link to the ECM or any BCM system. That is where you might need a program like Forscan to adjust/activate some parameters. |
