Fuel Pump Relay
Old Nov 26, 2002 | 10:03 AM
madferraristi's Avatar
Fuel Pump Relay
Perhaps one of you Lightning Gurus can answer my question about the Fuel Pump Relay.
I am installing an ATI on my standard 5.4L truck.
Rather than using the secondary Fuel Pump which comes with the kit (too noisy), I am going to go with a large Bosch in-tank pump, similar to the pump used on a Lightning.
I am told thet the Fuel Pump Control Relay is No. 301 on the underhood panel.
Does anybody know if this relay is the same part in my truck as opposed to a Lightning? If it is it will stand the load of my pump, if not then I must either replace it with a lightning relay or install a secondary one.
I either case I am sure I will need to run a larger wire to the pump also.
Old Nov 26, 2002 | 10:14 AM
LightningTuner's Avatar
Well, the Lightning fuel system is completely different from a standard F-150 (dual in tank pumps, high/low relay, stepped voltage system), so you really can't compare them or easily swap parts for one.
I don't see a problem with taking out your stock intank pump and putting in a larger one of the same desing, like a Walbro 255. The stock relay and wiring should easily be able to handle the minor amperage draw increase.
Old Oct 13, 2003 | 09:56 PM
LeviTaylor's Avatar
bosch fuel pump
Hi,
I'm getting ready to install my ATI kit on my 2002 SCrew 5.4. I've decided to lose the provided "inline" boost-a-pump and want th Bosch 255 lph pump. Does ANYONE know where I can buy that at? All I seem to find are the Walbro pumps.
Thanks!
Levi
