Anyone interested in installed electric water temp guage....here's a head's up!!!
Old Nov 10, 2002 | 08:13 PM
tallimeca's Avatar
if you don't want to tap the intake manifold for the water temp sending unit. Use the hose going from the rear of the manifold to the heater core. Use a 1/2 t fitting with 1/2, 5/8 barbs. The id of those hoses is 5/8, not 1/2. The bushings they send with the sender can be used to install the sender to the t. Then just use a worm gear clamp to clamp a spade terminal to the t fitting, then attach the other end to a ground.
