Heat & Humidity - Effect on ET'S?
Hi everyone,
Just get home from a day at the track. I am very disappointed with the times achieved today. The truck was very inconsistent, ranging from 103-106 mph & 12.9 - 13.1 With my mods, I should be around 12.5 -12.6. ? Today's times are as follows: 12.949 @ 103.92 60' 1.876 13.084 @ 105.62 60' 1.874 12.974 @ 106.31 60' 1.915 13.111 @ 106.69 60' 1.974 15lbs of air in Hoosiers Quick Time Pro's 86 degrees Humidity -83% BP 29.85 With the he?? should I do now? I am running Hoosier Quick Time Pro's too. I am beginning to wonder about these slicks. For some strange reason the truck is not running where it should be. Chris Staley JL Ram Air Kit JDM Flip chip Amsoil Synthetic Oil Breather Cap Boost Bypass Kit Single Blade Throttle Body 4lb Lower Pulley Interchangeable Kit Line Mod Valve Deep Sump Trans Pan & Filter Kit Jet Coated Long Tube Headers Twin Magna flow Full Muffler System Electric Fan Kit Cobra R Water Pump Drive Shaft Loop JJ's Stainless Steel Traction Bars Denso IT-20's [ |
Chris,
Heat and humidity play a big factor in your times. Especially the hot and sticky weather we've had in Ontario the past few weeks. I was at St. Thomas a few weeks back, running under similar conditions as you described, and the best I could manage was a 14.1 @ 99.xx (My truck is stock). I would wait for the weather to cool down, go back to the strip, and do a comparison of the results. You'll be very surprised. It's only supposed to be about 60 degrees this weekend. Perfect conditions. What were your 60' times? That will give you an indication if there's a problem with traction. |
Humidity and heat usually cost me about .4-.5 in the 1/4.
an easy way to fix the heat and humidity is Nitrous.
Also the JL power cooler helps allot. And the Quick time pros don't seem to work that goot for anyone. atleast thats what don was saying. |
| All times are GMT -4. The time now is 08:00 AM. |
