F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Lightning (https://www.f150online.com/forums/lightning-50/)
-   -   What gap with Denso IT 22's? (https://www.f150online.com/forums/lightning/90791-what-gap-denso-22s.html)
NTIMD8 Sep 18, 2002 08:03 AM
OK so The 6# Pulley and custom chip will be in tomorrow allong with the Denso IT 22 Spark plugs.
2 Questions.....
1) Id the computer hard to get at? I did not look to see where it is yet so I thought I would be lazy and just ask you guys :)
2) What gap should I use on the Spark plugs (Denso IT 22's)
Thanks guys!!
LIGHTNINROD Sep 18, 2002 08:34 AM
1. Disconnect the neg. battery cable, turn on the head lights, get a 1/4" ratchet(or a stubby 3/8") and a 10mm deep socket--use your left hand and reach down between the battery and the f/w until you can get the socket on the PCM harness bolt, loosen it(it won't drop--it's captured by the harness), pull the harness away from the PCM, go inside the cab to the rt. kick panel and locate the PCM--up against the body and pushed into the f/w, remove the black nylon clip at the back of the PCM, and pull/wiggle the PCM out of the f/w hole. NOTE: Turn the head lights OFF before you reconnect the battery cable.
2. .038" for 6 lbs extra--be very careful around the center electrode--they crack/break very easily.
Dan
NTIMD8 Sep 18, 2002 05:39 PM
Thansk for the info!! I love this board!! It is full of good guys who dont mind giving good advice and details!!
Thanks again!
,Jason
