IT WORKS! The Clarion sub works in my 01 L
I ordered the Clarion powered sub box from Crutchfield that J.D. Blackwell mentioned in his post.
and yes... IT WORKS! I was pretty skeptical at first but I popped in DMB Sattelite and couldn't beleive the sound! I think it is well worth the money! And best of all, it did work with the stock 01 L radio. Now it's not gonna cure you if you like the sound of two 12" solo barics playing in your civic hatchback... but it is a definite improvement to the stock system. The color is pretty close too. I haven't see it in good light yet. All I have tonight is my flourescent lights in my garage and a 60watt drop light. I haven't touched the gain yet. It seemed to be doing okay in its default position. I think you guys will be pleased with it considering the 150 bucks you paid for it. I'm liking even better since I had a credit with Crutchfield:D |
Pics asap pls!
Originally posted by BADBOLT2 Pics asap pls! And now its Spaghetti time!:p |
Glad to hear it works in the 01!
Mine should be in Tomorrow or Wednesday, also ordered some speakers to replace the door speakers :D |
COOL
So was it just plug and play or did you have to do some wiring?
Also did you have to run its own power or just rus off the radio Last do you think it will work on a 2002 should be the same right? Thanks Slick Also someone please post the link I could not find it @ crutchfiels site |
Im pretty sure it came with a built-in amp.
-Mike |
The 411 you requested...
First, the link to the Crutchfield page:
http://www.crutchfield.com/S-sTHJ972...020FF150LG&s=0 Second, this is the link to my photo gallery where I have some pics I just took: Pics of the Clarion Camouflage Custom Subwoofer Enclosure (Sorry the quality of the pictures is so crappy. My work's digital camera is about 6 years old) Also, the orange builders square in the pictures is 12" tall Keep in mind I haven't permanently mounted the box yet. For that matter, I haven't even put the radio surround plate back on or run the wires out of site. Yes, It has a built in amp. Everything was plug and play. There is one extra ground wire for the amp but it is not required for it to run. I think it's more for safety. I don't think it is a gound idea for amps to have mutiple grounds so it must be a chassis ground. Actually when I cranked it I could see the clock on the radio dim a little bit with the bass hits, so the amp must be pulling some current. I would imagine that it would work in any Gen II L. Now I'll try to find time to properly install the box... |
Re: COOL
Originally posted by SLICK0478 So was it just plug and play or did you have to do some wiring? Also did you have to run its own power or just rus off the radio Last do you think it will work on a 2002 should be the same right? Thanks Slick Also someone please post the link I could not find it @ crutchfiels site Daniel |
Looks good :D
Looks great man...........I'm definitely ordering one tomorrow, before all you guys snatch 'em up! ;)
Couple questions, though: -How much does it weigh, approximately? -Do you think you can flush mount a 6"DVD screen on the top, with some custom brackets/platform? -Do you have any dash vibration when the bass hits? -Do you need to run any power cables thru the firewall to the battery? -Are all instructions provided with the item and additional connectors? Sorry for all the dumb questions, but I wanna make sure. thanks, JC |
Oh, one other question.................does a middle passenger still fit with some leg room between the seat and the sub???
that's an important one thanks, JC |
oh come on guys, you gotta get some of these!!!
https://www.f150online.com/galleries....cfm?gnum=1664 which includes jeuves's |
ema100c,
looks good, thanks for the info and pics.. I ordered mine the other day when J.D. Blackwell first posted.. It's supposed to be here tomorrow or wednesday....:D JR |
Originally posted by MiamiWhiteSVT-L Looks great man...........I'm definitely ordering one tomorrow, before all you guys snatch 'em up! ;) Couple questions, though: -How much does it weigh, approximately? -Do you think you can flush mount a 6"DVD screen on the top, with some custom brackets/platform? -Do you have any dash vibration when the bass hits? -Do you need to run any power cables thru the firewall to the battery? -Are all instructions provided with the item and additional connectors? Sorry for all the dumb questions, but I wanna make sure. thanks, JC I just measured it and it weighs 12 lbs. The pocket on the top is a trapazoid shape. The top of the box slopes up to the dash. The bottom of the pocket is level so it recesses further into the back of the box closest to the dash. The dimensions of the pocket are 9" long on the wide part of the trapezoid. 7" wide on the other side, and 4.5" from front to back. The pocket is 3/4" deep on the front and 2.5" deep on the back. The outer measurement of the pocket trim is 6" from front to back. This should be enough to mount a 6" screen on the top if you remove the pocket and fabricate your own brackets and trim. I guess it just depends how far down you want to look at the screen. The front of the box is only 9" tall above the tranny hump. Look at the pictures and hopefully these dimensions will make sense to you. I haven't heard any vibrations when the bass hits. It isn't that big of a sub! The only thing that vibrated was my stereo removal keys when I left them in the pocket on top of the box. The sub sounds good but its not going to rattle the teeth out of your head. There are no cables going through the firewall. All you have to do is plug the supplied adapter inline with one of the cables that plugs into your radio. The instructions are supplied. Make sure crutchfield gives you that Ford adapter harness. The provided mounting hardware are some sheetmetal screws. No way I'm drilling any holes in my floor or dash. I planning on velcroing to the dash. As for your other question. There is approx 5.5" to 6" of space between the front of the middle seat and the front of the box. I guess I child could fit their feet in there. Maybe a person could stradle it and hold their feet back on either side... I don't use the middle seat so this just gives me an extra reason to keep it down to one passenger! JC, those weren't dumb questions. I like to be well informed myself before I drop some cash.:cool: Eric |
I ordered too
I just ordered mine also
I hope I ordered the right harness it said for 98-and up 020fcs1oe is the number we will see in a few days I do have a ? where can I get the puller for the stock radio or can I modify a clothes hanger or just buy the tool somewhere or can I remove the chasis with thradio in it somehow EMA100C what did you use ? I was looking at your pics how are you even supposed to put the hold down screws in or do those little tabs come off then pop back in some how or is there room on the bottom to use velcro all the way around just stick it to the carpet thanks again Slick |
