will a 4 lber get me 12's ?
Old Aug 11, 2002 | 03:58 PM
Groundstrike's Avatar
I've run a best of 13.48 with a chip, 90mm mass air, on f1's with 2.0 60 ft's with 65 degrees. We're 1700 ft above sea level here. What do ya think, what kind of improvements have you guys seen with a 4 lbr... Thanks
changed 12.48 to 13.48
Old Aug 11, 2002 | 04:35 PM
LIGHTNINROD's Avatar
I don't understand your post...did you mean 13.48 ?
I got into the high 12s with a 3 lber.
Dan
Old Aug 11, 2002 | 04:39 PM
red00Lightning's Avatar
If you meant that you ran a 13.48 then a 4# should get you into the 12's pretty well....as long as you can hook it up.
--wes
Old Aug 11, 2002 | 04:52 PM
frank2's Avatar
I still can't, no TRACTION at milan even with my hoosiers,might have not had enough air in them
Old Aug 11, 2002 | 08:06 PM
ttt
Old Aug 11, 2002 | 09:20 PM
Coldie's Avatar
probably
I ran a 13.1 with a 2LB...
Coldie
Old Aug 11, 2002 | 09:26 PM
soap's Avatar
I was hot lapping 12.5's with a 4# lower. But the air was flawless for drag racing that day.
Yes a 4# lower will easily get you into the 12's.........just have to wait for the fall to see the really good numbers.
--Joe
