Final Volant modification!
Hey Max!
Time for the Simple Green/H2O mod in the ole engine compartment, or something.
OBTW, what is the clear tubing coming from the intercooler reservoir with the blue clip-looking doo hickey near the coil packs?
Bob
Bob
Speedy,
Mine needs the cleaning mod more than this one does.
That's the pic off the AFM website. I didn't feel like taking a pic today.:o
The cable looks like someone was sitting on the dyno when this pic was taken.
That's the pic off the AFM website. I didn't feel like taking a pic today.:o The cable looks like someone was sitting on the dyno when this pic was taken.
Originally posted by NozeBleedSpeed
Yeah,that engine bay is much cleaner than Roger's.
I like to pile all of those parts in a circle around my truck and imagine what it would be like if they were all on it.
Your truck looks more and more like Rich's truck all the time.
So in other words...you ditched it?
Hmmm...looks like you drilled one too many holes in it....Did your engine hiccup when it ingested the residue?
That intake looks great! Nice Job! How are the improvements?
Originally posted by Crued
I'm surprized you removed the Volant. I have one also and love it. It looks great and I think is a good match for my setup (4#, chip, daily driver).
If they had based the kit around the 90mm, or even bigger for future MAF growth, and used a different type filter (Powerstack), it would be a great kit. They did not, and it is not. It's OK for 80mm vehicles though. Even for the 80mm kit they should have used a different type of filter. The end-cap blocks too much air.
I have 90mm MAF. I've never set an SES yet, and I've had it on for several months. I did put two 3" holes in the bottom of the box, but other than that, it's unchanged. In fact, I've never felt that the truck was starving for air. technically if it was unable to provide the air the blower needed, the filter would collapse.
Mine didn't set off codes after I cut the holes in the bottom either. Then I added the throttle body and that changed everything. The codes were not from starvation during top end or midrange driving; but, from airbox evacuation at tip in.
That does not mean that I was getting as much air as possible during regular operation of the vehicle. Just an adequate amount. The vehicle was probably running safer with the Volant. Less air means richer conditions inside the engine. The stock box is less restrictive.
