plug question again?
Old Jun 5, 2002 | 04:48 PM
EXCITED's Avatar
some say yea some say neah, will denso IT 20's work ok on a 4# pulley and chip?
Old Jun 5, 2002 | 04:53 PM
beefcake2002L's Avatar
Registered User
Re: plug question again?
Yes, they will work. However, they may be a bit to hot and cause detonation towards the top of your RPM band though if weather conditions are just right...
Best bet is to call Sal and ask him. There isn't much he doesn't know regarding "L's" and any/all performance mods...
I think he will say IT24's though... maybe not...
you can get his number at www.powersurgeperformance.net
Old Jun 5, 2002 | 04:57 PM
EXCITED's Avatar
the reason i am asking is i have not installed chip oe pulley or plugs yet , but Mark at LFp said they would be ok with my setup?
LightningTuner's Avatar
Beef, thanks for the refferal . Actually, I suggest IT20s from stock up to 4 lbs extra. Over that, it's the IT24s. We tested the 22s, and they seemed to run, and fail, the same exact ways the 20s did, that's why we suggest the 24s instead, The 24s are a non-porjector style cold plug, perfect for spray over 100 shot and boost over 4 lbs extra.
BlkBanshee's Avatar
Suspended Pending Email Reply
IT24's are quite cold, for only a 4# pulley... 20's should work just fine - any colder than that with a 4# pulley and I think you'll foul pretty quickly... Anyone agree/disagree?
Old Jun 5, 2002 | 04:59 PM
BlkBanshee's Avatar
Hehe... Sal must have been typing when I started to respond!
EXCITED's Avatar
Thanks for the input Sal, iam going to use the IT20's since i already ordered them at 0.40 or some one said they are pre gapped at 0.42?
Old Jun 5, 2002 | 05:02 PM
I suggest anywhere from .038-.040. I don't like to go higher than that. And lower gaps are for more serious powerplants.
Old Jun 5, 2002 | 05:05 PM
Registered User
Told ya he'd know... looks like I was mistaken... thanks for chiming in Sal...
Old Jun 5, 2002 | 05:07 PM
StruckBy99's Avatar
Hey Sal, what did you mean by this?
I especially dont understand the run and FAIL part.
Jason
Old Jun 5, 2002 | 05:16 PM
Jason, plugs fail under certain conditions. Even the best plug will fail if it's not the right application. If you run an aggressive tune, or high amounts of boost, with a plug that cannot dissipate the heat to the head casting fast enough, it will overheat and burn up. I've seen some chips that are just plain so poorly tuned that no matter what plug you have, it's gonna die, but you can run an aggressive power level with the right plug and still be safe.
What I was saying about the 22s, is that we've seen them fail in the same situations as the 20s, meaning they were no better than the 20s. The 24s have held up great so far, and I've not heard anyone say they have felt any drivability differances like the BR7s have.
Old Jun 5, 2002 | 05:19 PM
EXCITED's Avatar
hey Sal ,did'nt denso improve thier It 20's idle etc..?
