Brake pads ????
Old Jun 2, 2002 | 10:42 PM
99BlkLitng's Avatar
Brake pads ????
What is a good brake pad to use when the stock ones wear out? I have heard of the Ceramix pads from Napa but do not know how well they compare to stock and what the part # is. Let me know what pads are good along with part #s if you have them.
Damon
Old Jun 2, 2002 | 10:51 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Hawk's
front HB301F.630
rear: HB299P.650
approx $140 though
Bob
Old Jun 2, 2002 | 10:54 PM
svtmike24's Avatar
cant you just take it back to the dealer for new brakes, or will they not do it. or is it to expensive to take it back to the dealer. im also needing new brakes they squel even when im not on the brakes,lol, its getting really old too and embarrasing
Old Jun 2, 2002 | 11:46 PM
Spike Engineering's Avatar
Originally posted by Speedin Bob
Hawk's
front HB301F.630
rear: HB299P.650
approx $140 though
Bob
My choice also. They're less expensive than OEM pads and they'll last longer than the ceramics.
Spike
Old Jun 3, 2002 | 01:33 AM
Andy G's Avatar
If your truck is still under waranty then Ford should replace them.
I had 2 set of brakes replaced on my old 93 T Bird and 1 set on my 95 Mustang...under waranty,no charge.
Andy G
Old Jun 3, 2002 | 03:31 AM
clonetek's Avatar
how good would the Hawk pads be if they were on a daily driven vehicle? i dont go to the auto-x or dragstrip much.. so i need something that will be good for 2 years worth of stopping.
the stock ones have lasted that long.
also, does anyone know how much brake fluid is in our system? i want to put in fresh OEM fluid. what kind of ford fluid should i use?
thanks!
Old Jun 3, 2002 | 10:14 AM
clonetek's Avatar
btt
Old Jun 3, 2002 | 11:04 AM
thanks!
If I had to replace pads, I'd get the Hawks for the street. My pads (and rotors) didn't last long because I ran them in track events.
Regarding fluid, the Ford HD fluid is fine for the street.
Spike
Old Jun 3, 2002 | 11:21 AM
Jay Lincoln's Avatar
I'm running the Hawk HPS compound. These work great, especially when they get hot. They are very low dust compared to the Performance Friction brakes that these replaced.
Old Jun 3, 2002 | 11:31 AM
clonetek's Avatar
where can i get the hawk pads?.
and does anyone have the part number/name of the ford brake fluid? i went to the local dealer last week, and all they had was castrol brake fluid.
Old Jun 3, 2002 | 12:26 PM
Don's Bolt's Avatar
Question Nyone ever hear of these
http://www.porterfield-brakes.com
I just ordered some R-4S Carbon Kevlar pads
I went lookn for the Hawks, but all the places I called were out of stock.
I hope they are good, we will see????????????
Old Jun 3, 2002 | 03:09 PM
Don, I started out with the Porterfields. They are a very good pad. They are low dust and will stop the truck better than stock. I got about 22k out of mine.
When you first iinstall them, you might find thay don't work very well. Clean the rotors well before install. I didn't do this.
After a couple of hundred miles, murder them. I had to make several high speed stops, until there was smoke coming from the front brakes. They worked great after that.
I have gone with the Hawk pads, as I was looking for a little more agressive pad for LA stop and go. They definitely work better when warmed up. Go easy on the first couple of stops until they are.
Old Jun 3, 2002 | 04:45 PM
clonetek's Avatar
so if someone pulls out in front of me while driving in morning traffic, i'll have a greater chance of slamming into them?!?
no thank you!
i'll go with the ceramix or stock ones i guess
Old Jun 3, 2002 | 05:03 PM
RTKILLA's Avatar
no thank you!
brooks the ceramix pads are nice bro, and you get a lifetime warrenty on them so when you get down to the bottom of the pads just heat them up a bit and crack them and you'll get a new set for free from napa.
I just did my new rotors from Frozenrotor.com and the guy said it would be best to use new pads to seat them perfect, so I just went out and rosted my pads and napa gave me a new set cause two of them had some minor cracks that where like nothing! They have hardly no dust at all, they don't squeal that much at all, they last londer and they brake harder! you'll like them for street driving and the track once and awhile. thats what I do with mine.
I put about 10,000 miles on my first set and they still had allot of pad left good for another 30 K atleast!
Old Jun 3, 2002 | 06:00 PM
no thank you!
Misinformation. They grip better when they get heat in them. They aren't like a race pad that doesn't have grip until they are up to temp. Still, they grip better than stock.
Spike
