new Hoosier's for sal.. nice !
Sory sal, I had to show every one they look so killer!!!:p
https://www.f150online.com/galleries...3332&anum=1299 |
Get that thing off of jack stands!!! LOL
https://www.f150online.com/galleries...1299-13332.jpg Looks good though.... |
Hmmm
Were there any 'fitment' problems with the rear Bogarts, .ie. calipers? See Sal's earlier post.............
Dan |
I decided to bite the bullet too!
https://www.f150online.com/galleries...-255-12498.jpg They will get their first run at FFW in Atlanta on the 19th of April. Well OK maybe a few runs before then! |
Flats Man:
Why not run them at the NMRA event next weekend? Reynolds, GA is a lot closer to your home than Atl. is.
Gonna be a lotta Lightnings here then:) . Dan |
Hey Sal or anybody else that knows. What size are the front runners on your truck?? I am about to order some but want to make sure I get the right ones. They will go on 15x7 in rims so let me know my options. Thanks!!
522-18080 Size: 23.0x4.5-15 Weight: 9 lbs. $ 128.99 522-18090 Size: 24.0x4.5-15 Weight: 10 lbs. $ 132.99 522-18100 Size: 25.0x4.5-15 Weight: 11 lbs. $ 135.99 522-18105 Size: 26.0x4.5-15 Weight: 11 lbs. $ 136.99 522-18107 Size: 28.0x4.5-15 *I think these are the ones I need* Weight: 12 lbs. $ 138.99 522-20100 Size: 22.0x2.5-17 Weight: 4 lbs. $ 125.99 |
Travis, the 28s are what I have. But I really don't suggest using them on a 7" wide rim, because they are really thin, the tread is only about 3.5-4" wide.
Originally posted by LightningTuner Travis, the 28s are what I have. But I really don't suggest using them on a 7" wide rim, because they are really thin, the tread is only about 3.5-4" wide. |
Well, I think you have a few problems. First off, you are looking at 15" tires. There's nothing wrong with that, but you are looking at 16" rims. The Baja's are 16x8s. They don't make a smaller or thinner size with our bolt pattern. I am using a 15 x 5 on the front. The tires are rated at 4.5 wide, but if you were to look at them, they are wide at the sidewall, but they taper to a very small footprint. Keep in mind that these are front drag slicks, not street tires. So you will either have to get a 15" custom front rim, or use a 16" tire on the Bajas. Hope this helps.
:( That stinks. I though for sure their 15x7s were in our size and bolt pattern. I guess Ill just get the rears then. Thanks for your help.
Originally posted by Caka :( That stinks. I though for sure their 15x7s were in our size and bolt pattern. I guess Ill just get the rears then. Thanks for your help. |
| All times are GMT -4. The time now is 07:55 AM. |
