F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Lightning (https://www.f150online.com/forums/lightning-50/)
-   -   Installed Metco's valve cover breather (https://www.f150online.com/forums/lightning/59772-installed-metcos-valve-cover-breather.html)
415cid Goose Dec 15, 2001 08:25 PM
Put it on Thursday and so far no oil in the throttle body. Install is really easy. The kit eliminates the draft tube. I'll keep you guy's and gal's posted.
SCOTTODOG Dec 16, 2001 03:57 PM
I installed two tanks on on each valve cover after 1000 miles only the one on the passenger side had about a pint of oil in it. I removed the one on the driver side and left the one on the passenger.
LIGHTNINROD Dec 16, 2001 04:02 PM
I just 'capped' off the PCV and put a small K&N filter in the cam cover hole.
Dan
DL Dec 16, 2001 04:06 PM
HEy Dan,
Was that the CornerCarver kit you used? ;)
LIGHTNINROD Dec 16, 2001 04:15 PM
Yep
Originally posted by DL
HEy Dan,
DL, I had some left-over 'parts' and put them to use. Hope it works out. I want a 'clean' A/F mixture with no added crankcase oil.
Hope to see both of you at SDR:) .
Dan
Hamrhead Dec 16, 2001 07:38 PM
I took a trip to see the 'Pep Boys' and bought me a small, chrome breather for about 10bux. Brought it home, rigged up a short length of vacuum hose to it, and slapped it on. Plugged the port on the underside of the intake tube and I was done. It took about 10 minutes and not only does it work perfect, but it looks decent too! :)
Mondo1 Dec 16, 2001 07:44 PM
Scottodog--That side is a problem.There is no sheild to stop the oil from filling the breather.Best bet is to put cap back on it.:(
DL Dec 16, 2001 09:26 PM
Hey,
I'm kinda lost. I removed the oil filler cap and installed the Ford Racing screw in filter in the oil filler cap stem.
Now I was thinking about putting a filter on the crankcase tube on the drivers side. Ford Racing makes a slip on type filter that I was going to use on the drivers side.
Hey Mondo1, you talking about removing the pipe from the passenger side, why remove that side when you can use the oil filler.
Well If you get the Metco, they have done all the leg work for you. It's your choice, buy a kit or go to the parts store to get your own.
I think CornerCarver posted all the parts you needto get from your local parts store.
Odin's Wrath Dec 16, 2001 09:53 PM
Mark@LFP sells one that installs in place of the oil filler cap, also. Billet base and chrome cap. 'Just ordered it today.:D
DL Dec 16, 2001 10:29 PM
Hey,
Check these guys out ..
http://www.mgwltd.com/lightning_and_f150.html
http://www.metco-inc.com/
Hey Odin's Wrath,
Nice sig...
NOSTROMO Dec 16, 2001 11:16 PM
Anyone have pics of that oil catching sump?
DL Dec 17, 2001 12:08 AM
Sounded like it was a couple of 1 gallon milk jugs with straws coming out of the valve covers. I think they were held in place by Duct tape. Hope this helps.
clonetek Dec 17, 2001 03:15 AM
i used:
K&N filter p/n 62-1020 $17.99
"help" ford pcv system elbow p/n 47044 $1.99
"help" 5/8" bypass cap p/n 02252 $1.99
3" of autozone brand 5/8" heater hose $.75
clonetek Dec 17, 2001 03:18 AM
here is the installed filter
clonetek Dec 17, 2001 03:20 AM
and here is the blockoff cap.
