slapshot |
09-22-2012 04:26 PM |
What kind of airbags are you talking about, like air suspension or helper airbags? I have Firestone airbags on the back of my Lightning for towing. Under normal driving, I have no air in them. When I tow my boat (4000-4500 lbs), I inflate them to keep the rear end from squatting.
First thing I would do is see where they are leaking from. Likely the leak is from 1) air air fitting, 2) air tube, or 3) the airbag itself. The fittings and tubes can easily be replaced. Once you get to a leaking airbag, it may just be cheaper to install a whole new set depending on the replacement cost.
