F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Lightning (https://www.f150online.com/forums/lightning-50/)
-   -   Anyone's Tonneau Leaking? (https://www.f150online.com/forums/lightning/44990-anyones-tonneau-leaking.html)
My01Bolt Jul 9, 2001 11:52 PM
This is the factory installed soft tonneau. After I washed it, opened the cover and there had to be a gallon of water in the bedliner!!!! Cleaned it up, climbed inside and low and behold, I saw the light!! The rail closest to the cab has spaces (about 1/2 inch) on both ends where it meets the side rails. Is this normal??? Does anyone else have this problem??? There was A LOT of water in there. HELP!!!:::(
BfB Jul 10, 2001 12:18 AM
The soft cover isn't waterproof. It was designed to keep a lot of weather out, but not a sharp hose down or a pressure wash. Your's may just need adjusting (the rail).
BfB
CBQB3 Jul 10, 2001 02:03 AM
Don't feel bad
Don't feel bad. My $775.03 Snug-Lid leaks even when I was it with my backyard hose. It's just one of those thangs.
As I would say, "Ain't nuthin' but a chicken wang on a strang." :p
awhittle Jul 10, 2001 07:23 AM
Caulk the two little holes closed. The water runs down the ridges on the sides of the truck and turns into the grove at the front corner of the bed.
Hope this helps
Andy
