Cold air intake help
Old Apr 17, 2011 | 10:12 PM
johnrodgers's Avatar
I bought a 2001 lightning a while ago and im trying to get a few things on it squared away. The entire intake system is in bad shape, im not entirely sure whats going on with it to be honest. It go's from an accufab throttle body to a JLP thundertube then to a 90 mm MAF. the problem is that it looks as if the previous owner Jimmy rigged the MAF end of the thundertube to actually fit. I almost want to get rid of the entire system as is and replace it with something that isnt such an eye sore. Cant anyone recommended what direction i should take with this? here are some pictures to better illustrate whats going on..
Bottom of thundertube..
Old Apr 18, 2011 | 10:13 AM
jaymz's Avatar
OOOOOoooooooowwwwwww, that's ugly, all right. The JLP filter box looks OK, but where's the filter? Get a C&L intake tube and you should be OK, but where's the 3 vacuum lines that should be attached under the intake tube? What a mess.
Old Apr 18, 2011 | 10:59 AM
I was cleaning the filter at the time and there are only two lines that lead to the tube I believe although they don't serve any purpose since the oil that seeps From the TB pools Past the holes ! I need to put some crank case breathers on my covers though because it's a substantial amount puddling around the MAF that I think is also screwing up a/f ratio. Thanks for the advice If I can keep the JLP box then all the better.
Old Apr 18, 2011 | 11:44 AM
phil6608's Avatar
I had one of them thunder-tubes and had problems with it staying connected to the TB.
Got rid of it and put the C&L in there. Works a lot better.
Old Apr 18, 2011 | 07:17 PM
Thanks you guys. just the advice i needed. im placing my order for the C&L as i post this.
Old Apr 18, 2011 | 07:19 PM
Hey phil what kind of intake plenum is that by the way? also why is it that we have the same KB but yours is so much more shinny !
Old Apr 18, 2011 | 07:31 PM
I cant seem to find the Lightning's intake tube on C&L's online store? its listed on their homepage but not the online stores catalog.
Old Apr 18, 2011 | 07:32 PM
phil6608's Avatar
It's a JLP plenum,
and I send the blower out to be polished.
Old Apr 18, 2011 | 07:35 PM
phil6608's Avatar
LFP has the C&L.
http://www.lightningforceperformance...e_Pipes/grid/1
