Quick Question
Quick Question
I just recently replaced my accessory belt and had to remove my stock lower pulley. After changing the belt and re-installing the stock lower pulley i could not find a way to hold the converter and tighten the stock lower pulley. I tighten the pulley as much as i can (while also turning the engine) and tighten the tree bolts that are the housing on the stock lower pulley. I thought to myself wouldnt the engine itself over time tighten the stock lower pulley. I turned it on and it ran normal. What do you guys think?
LPF sells an inexpensive tool that locks your converter, easy install that locks the engine, and keep it from turning. (You cloud probably make your own it is just a steel bar with two holes in it)!
