Help for better traction!!!
Old Jun 22, 2001 | 01:13 PM
noelvm's Avatar
Talking
HIGH ROLLER--The question still remains of your launch RPM. It is critical to good 60'. Check with your friends at your tract. If you have a problem looking at the tac when staging try this rountine. Stage second lite first. The moment the other guy stages second lite look at tac run rpm up over your selected launch rpm and let it drop back down. Hold it and return you concentration to the tree. Remember, you have a minimum, on computer controlled trees, after both guys stage of seven seconds before the lites will come down. If you are unsure of this at your track, ask the starter.
Wow, I'd like to launch at your track. Mine has horrible traction especially at nite with the high humidity. Good Luck!
noelvm
