F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Lightning (https://www.f150online.com/forums/lightning-50/)
-   -   Too Much WATER WETTER is a waste, here's why: (https://www.f150online.com/forums/lightning/33900-too-much-water-wetter-waste-heres-why.html)
BfB Jun 14, 2001 04:16 PM
<font face="Verdana, Arial" size="2">&gt;Pardon me, but isn't TOO much Water Wetter, especially when you do not use
&gt;ANY water, a bad thing?
The use of 100% WaterWetter would just be a waste, though it won't
hurt or diminish the properties or performance.
&gt;From my understanding it is and requires water in
&gt;order to work correctly, and more than 2 bottles usually is a waste. I've
&gt;also come to believe that too much will actually reverse the cooling effects
&gt;and could possibly cause MORE heat.
Too much WaterWetter doesn't produce the opposite effect.
I would recommend one ounce of WaterWetter to each quart of distilled
water or 4 ounces to a gallon.
&gt;
&gt;Please, can you give me any insight, and keep in mind that I will post what
&gt;you state on a message board in 100% accuracy.
&gt;
&gt;Thank you so much!
&gt;
&gt;James Parker
Regards, Dave
Red Line Oil</font>
https://www.f150online.com/f150board/smile.gif
BfB
JeffsLightning Jun 15, 2001 12:17 AM
Who the F*c* is James Parker? Everyone knows you only need 1 maybe 2 bottles max of the pink stuff...
99.5 Lightning
Gone but not forgotten
01 picked up on 5/5/01
hud@mc.net
BfB Jun 15, 2001 12:58 AM
I have no idea who the fuxer is ( https://www.f150online.com/f150board/wink.gif) &lt;G&gt;
Anyhoo, NOT everyone on here knows that. Read one of the other posts made earlier today about this topic.
BfB
2001Bolt Jun 15, 2001 03:16 AM
You guys are killing me!!!!!!!!! https://www.f150online.com/f150board/smile.gif https://www.f150online.com/f150board/smile.gif https://www.f150online.com/f150board/smile.gif https://www.f150online.com/f150board/smile.gif
  • 2001 Lightning (WHITE)
  • 2001 SuperCrew (RED)
  • '90 Pro Street Mustang GT 1/4 7.50ET@185MPH.
  • '23T Altered 1/4 7.90ET@170MPH.
    2001Bolt@group1320.com
http://www.group1320.com
99svtlightning Jun 15, 2001 09:16 AM
Read the back of the water wetter bottle.
99 Lightning- JL equipped! JL Ram Air, JL Daiblo Chip,90mm MAF,JL Power Cooler, Level 10 shift kit,PSP Lower pulley, Single Blade T/B, Bassani exhaust, NGK's. 12.42 at 109.6..Full trim and stock convertor, MT Street ET's.
New times w/ JL converter coming soon!
BfB Jun 15, 2001 09:33 AM
<font face="Verdana, Arial" size="2">Originally posted by 99svtlightning:
</font>
Here, I'll post it...I have nothing better to do this morning:
<font face="Verdana, Arial" size="2">Cooling System Heat Transfer Agent for Use with Water or Antifreeze / Water
Improves the ability of coolant to we heat transfer surfaces by 50%. This provides significantly better coolant contact in the cylinder head and can reduce coolant and head temperatur by as much as 30°F. Can be used with 100% water in racing but does not protect magnesium or alter freezing point.</font>
and...
<font face="Verdana, Arial" size="2">Directions for use 1 ounce (3-4 capsful) per quart or 1 bottle per automotive cooling system or 12-20 quarts. Less than 50% antifreeze provides further improvement in temperature reduction, but at least 15% antifreeze should be used in street vehicles. This product provides excellent corrosion protection for modern cast iron, aluminum, and brass systems. Can be used with distilled or tap water. Change cooling system annually for best protection.</font>
Everything looks fine and seems in check. The only thing I have to wonder w/ is their recommendations on how much to use. The bottle has 12 oz. of product in it. They ask you to use 1 ounce (3-4 capsful) ...okay which is it, 3 or 4???... per quart, which means 12 oz (1 full bottle) of this product should work for 12 quarts. Now, then it goes on to say "...or 1 bottle per automotive cooling system of 12-20 quarts."
So in essence to get the same cooling effects as using 1 oz to 1 quart, those w/ 20 quarts capacity should use 1 bottle and 8 oz., not 1 full bottle.
Anyhoo, was there anything on the bottle that made you think different? I do have an old style bottle I think, so maybe they changed the literature on the new ones.
BfB
Speedin Bob Jun 15, 2001 10:38 AM
Bubba,
your said you own a niteclub, why not use a jigger or a shot glass from the bar?
or better yet, have one of your bar staff teach you how to free pour... https://www.f150online.com/f150board/biggrin.gif
Brake Late, Dive Deep
Speedin Bob, Owner/Operator/Pilot
Lightning #2504, 6/17/99
NLOC # 438
**THIRD intercooler**
http://www.zing.com/picture/pb08e49e...0.jpg.orig.jpg
http://www.bulldogneon.com/knockout.gif
Zing Site Speedin Bob's pics
