Someone 2 Post some Pic's
Someone asked me to post a couple of pic's of my truck with 335 rears on BABolts widened rims. Who can I email pic's to? Also does anyone have any tips on taking a picture under the truck, my camera keeps adjusting to the higher light level and it just looks black under the truck between the tires.
Thanks Dennis |
svtf150@cfl.rr.com
Also here is an easy way to post your own pictures if you want: In order to post a picture you must have an online picture host. I use www.zing.com , it is a free service. After you open an account and upload your pictures to it, you can then post them here. The way to go about that is this: go thru your album and find the pic you want, (it is best not to double click the picture because it could be too large)then RIGHT click on the pic, then choose "properties", then point the cursor at the URL(address) right clice it then choose "select all", then right click again and choose "copy", you can then choose cancel. Now the address is saved for a "paste" (I usually keep 2 windows of Explorer open when I post more than one pic). While making your post here (or any UBB sofware board) find the spot in you piece that you want the pic to be and do the following: [img]IN THIS SPACE YOU SHOULD NOW RIGHT CLICK AND CHOOSE "PASTE"[/img] Make sure to use [img] in the beginning and [/img] at the end, and not use the space bar and you should get the picture up! Good luck! Tom [This message has been edited by blue blood (edited 06-04-2001).] |
I can post the pics too... araja@megapathdsl.net
MNlightning were are you from ?
MN,
If it keeps going black, you can do a couple of things. First, aim the camera at a very dark spot underneath the truck above the axle. Without moving the camera, press the shutter button halfway until it focuses and gets a 'fix' on the exposure. Without letting up, lower the camera and take a pic. You can also choose the 'fill' flash setting. This will add flash light to the darker areas, thereby making the photo in balance. Or do both methods at the same time. Works for me. |
Thanks, guys I will take some and post them Tuesday afternoon.
Thanks Blue Blood I'll try it and if I fail I will use your email. retics4me.. Maple Grove gforce.. Thanks hope that works, the pic's I took yesterday didn't show off the tires at all. I think they look nice and have recieved several compliments on them. Just need to get the truck lowered now. |
| All times are GMT -4. The time now is 07:02 AM. |
