F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Lightning (https://www.f150online.com/forums/lightning-50/)
-   -   Installed K&N air filter didn't notice any difference (https://www.f150online.com/forums/lightning/30762-installed-k-n-air-filter-didnt-notice-any-difference.html)
SVT Bob Mar 20, 2001 07:58 PM
I installed a K&N air filter today. In my 2000 L. Took it out for a spin.A few times I went WOT. Didn't notice any performance difference. If there was any it was probably to little to notice.I hope I get better gas milage out of it at least. Bob
dogleg Mar 20, 2001 08:32 PM
Hey Bob,
Great start. You will get some improvement but you may not feel a lot of it; you should hear quit a bit more noise. The main point is you have taken the first step. Things will get better each time you drop a little more money.
Good luck!
99.5 Ford Lightning - Full Bassani exhaust, Swanson Performance Chip,Pro-m,undersized pulley,3.73 gears, alu. driveshaft,Transgo shift kit,Cal-trac bars, cobra type hood, snug top cover,2" drop in back, yellow stripes down red truck.
12.93@ 105.6 on F1's, 378 RWHP
http://www.zing.com/album/?id=4294235379
<A HREF="http://www.zing.com/picture/p42c36b5d4c9f986aa26c3cbd4c8e55d7/ffad202c.jpg.orig.jpg" TARGET=_blank> http://www.zing.com/picture/p42c36b5....jpg.thumb.jpg </A><A HREF="http://www.zing.com/picture/pe3bcc04098fe5357ec7af93b20d8771f/ffad2027.jpg.orig.jpg" TARGET=_blank> http://www.zing.com/picture/pe3bcc04....jpg.thumb.jpg </A><A HREF="http://www.zing.com/picture/p134bd307c0909833c8f88d5f48641ca9/ffad202a.jpg.orig.jpg" TARGET=_blank> http://www.zing.com/picture/p134bd30....jpg.thumb.jpg </A><A HREF="http://www.zing.com/picture/pe014316f2347f4ed6dccb540aa993bb2/ffad202d.jpg.orig.jpg" TARGET=_blank> http://www.zing.com/picture/pe014316....jpg.thumb.jpg </A><A HREF="http://www.zing.com/picture/p52c9be2c81bb40b5cf2b6ffe6640d3f8/ffad2028.jpg.orig.jpg" TARGET=_blank> http://www.zing.com/picture/p52c9be2....jpg.thumb.jpg </A>
Reddawgy Mar 20, 2001 08:40 PM
Hey Bob, i felt the same way. I put the stock back in and returned the K&N, kept the oil. I now have the PSP kit, big difference. Performance and sound, i love it. I am sure all the kits are similar, but thats what i did.
Silver '00 Lightning.
#3962/4966 6/16/00
PSP filter kit.
JL 300/4 amp, JL-XR's, VR's and 10WO, Crossfire 75.2 amp.
Ligted Logos.
Xenon bulbs X 4.
Clear corners, Altezza tails on order.
THEAUTOMAN Mar 20, 2001 08:41 PM
My first induction mod was cutting some holes in the bottom of the stock airbox. That helped about a tenth at the track. Now I have a large open element filter and it runs exactly the same as the modded airbox with the stock filter. I have had a K&N on every vehicle I've owned in the last seven or so years (which is about 10 vehicles or so) and have never seen an improvement on the track. I use them 'cause they never have to be replaced not because I expect a 20 HP gain. The only way a K&N or similiar filter is gonna improve performance is if your paper filter is in bad shape or if you go to a different type ie open element vs stock airbox. I'm not against replacement type filters-I just put one on my new bike-but in my experiences I have never seen a performance improvement Just my .02
2000 Silver L #4906
Best 1/8th mi stock:9.13
Best with R9 and new motor: 8.50 at 82.5
1995 Stang : (wifes'car) 12.30 1/4 mi
1972 Skylark: 7.16 1/8, 6.70 on the bottle
gforce Mar 20, 2001 08:52 PM
What AUTOMAN said. If you used the K&N drop-in filter instead of the conical one (you didn't say) then holes in the bottom of the stock box will help like LTNBOLT did to his.
If you used the K&N filter cone, you might want to try the 12" S&B.
Black '00
#1,757 built 3/30/00
Clear corners
JDM street program
JDM 2# blower pulley (ordered)
J.L. Stage II ram-air
FRPP Oval throttle body (ordered)
90mm MAF
MagnaFlow Exhaust
LTNBOLT Mar 21, 2001 12:15 AM
Yeah, what Automan and gforce said.
The 90 mm MAF will give you a good reason to put the 12" S&B filter on.
It's all under Airbox on my website. The boost gauge tells the tale. I updated it with the evolution to the 90 mm MAF.
Later,
Chuck
Black 00
Chuck's Lightning Page
[This message has been edited by LTNBOLT (edited 03-21-2001).]
DUCK01 Mar 21, 2001 12:24 AM
Do you need to reset your memory for something like this to feel all of the benefits?
November 18, 1999 We will not forget.
The fallen 12 will live in our hearts forever.
Fightin' Texas Aggie Bonfire 1999
Jay Lincoln Mar 21, 2001 01:25 AM
Bob, I did the same thing and had the same result. I couldn't feel any appreciable performance difference. Two weeks later I canned the K&N and airbox for a Pro-m mass air and cone style filter. I noticed a big seat-of-the-pants difference. It must have done some good, because with the Pro-m and a Swanson chip, I made 377 RWHP. These are the ONLY mods that I have made.
Red 00"
Pro-M mass air
Swanson Chip
Gaylord's bed cover
