Need some help removing the head light switch
Old Jan 12, 2001 | 09:19 PM
John893's Avatar
Post Need some help removing the head light switch
I am trying to remove my headlight switch from my dash. I am afraid of scratching or breaking something. Anyone have suggestions on an easy way to get the switch out? It is about 28 degrees outside so that might ad to the breakage factor.
Thanks for any help
John
93 Teal Cobra #4656
2000 Silver Lightning #4524
Old Jan 12, 2001 | 09:30 PM
PFA's Avatar
PFA
Post
John893
I believe there may be some info in this in the FAQ section for L's. You may want to check there.
Old Jan 12, 2001 | 09:33 PM
Silver_2000's Avatar
Post
John
Take a look at the Fog Light "How To" on my site. It should help
Doug
Picked up Silver 2000 Lightning 2/28/00!!
1st run 13.9 sec 1/4 !! Best Run 13.43
drbdkb@hotmail.com
My Web Site www.SVTLightnings.com
2000 Lightning, FMS 3.73 gears ( Expensive ), PSP 4 Way Chip ( Retired due to pinging ), PSP Intake, Valentine 1, Snuglid, Bedrug, Lighted Ford Logos, Superchip R9, and 3m Panther Black nickel tint, Clear corners., Boston Acoustics 5x7s and Components, Alpine v12 5 channel Amp and JL Sub.
Old Jan 12, 2001 | 10:08 PM
John893's Avatar
Post
I looked at Silver_2000_ web site and don't know what is meant by "I simply used a small screwdriver to coax these clips into releasing the console from the dash" What does coax mean? I stuck a screw drive in and tried to release the clips but am not sure what to do? Do I push up on the clips, or down?
93 Teal Cobra #4656
Old Jan 12, 2001 | 10:15 PM
WHAT04's Avatar
Post
All the clips push towards the switch to release them. However, something flat, approx. 1/2" wide and long pushed in by all three clips is the best way. Something like feeler gauges would be best.
I also removed some screws around the dash plate so that I could reach in behind and push the switch out. It can be a real b!tch!
Be patient and do it right. It will come out.
2000 Red Lightning - #835 of 4966 Born 3-8-00 / Delivered 3-22-00
22% Window Tint, Clear Corners, MPulse LoPro Tonneau, AIM 2" Drop Shackles, Bed Rug, PSP Filter Kit, Other Goodies, Group Buy Floor Mats
Best time: 13.45 sec. @ 101.99 mph
2000 Red Trans Am Ram Air WS6, 6 Speed - Delivered 2-15-00 - Awesome Looking Car
My Zing.com Album Click Here
Old Jan 13, 2001 | 02:31 AM
Burninout101's Avatar
Talking
Turn the headlights on with the fog lights pulled out, Now take a small screw driver and under the **** there is a hole, take the **** off. Replace the **** upside down and turn the lights off, and SLOWLY & CAREFULY pull the assymbly out of the hole. There you go its out to put back in just put it in turn lights on with fogs, take **** off, replace correct way and your set.
P.S. This worked on my 99, Im not sure for the 00, tho.
Old Jan 13, 2001 | 07:19 AM
Flats Man's Avatar
Cool
Burnouts discription is explained in detail, with pictures, in the Haynes Manual for your truck. This manual has come in very handy on many occasions and can be bought at most automotive stores.
Old Jan 13, 2001 | 08:29 AM
PFA's Avatar
PFA
Exclamation
I believe that the description that Burninout101 gave is only for the '99 L. The 2000 L has a different switch assembly.
Old Jan 19, 2001 | 03:28 PM
John893's Avatar
Post
Does anyone know if there is a trick way of getting the switch out for the 00's like Burninout101 said for the 99's or if his way will work on the 2000's?
Thanks again.
93 Teal Cobra #4656
Old Jan 19, 2001 | 04:05 PM
Lightningquick's Avatar
Post
If you can come down to salisbury,My friend who owns a radio shop will do it for you in 5 minutes.I think its different on 2000s. No need for an appt,just call me and its done free of charge,the right way.
I want to say that you need to pop the dash out and go about it from behind.Im almost positive
