pushed down seat
pushed down seat
Is there a way to fix the seat where it is pushed down. My driver's side is pushed down on the outer portion. The passenger seat is fine. I know it is from getting in and out of the truck (heavy drivers). It was like this when I bought it. Is there a way to get it back up like it was without buying a whole new seat. Thank
I had the same problem, but it just wore out, the dealer fix it under warranty.
They took the seat out, remover the cover, and added additional foam, that was it.
I’m sure that you may be able to re bend the coils (to lift or straiten).
Removing the seat is no big deal, 10 min job; the cover comes right off also.
And the foam, use you’re own discretion!!
The foam has probably split. Take it apart, glue the foam back together and put some split foam pipe insulation over the support bar to keep it from cutting through/splitting the foam again.
