F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Lightning (https://www.f150online.com/forums/lightning-50/)
-   -   What will the 01 maf do for our 99-00's (https://www.f150online.com/forums/lightning/28899-what-will-01-maf-do-our-99-00s.html)
ShadowBolt Jan 15, 2001 10:36 PM
Maybe Ba or someone else can answer this. If we install the new maf will we need to have our chips reburned?
Jerry
WCFan Jan 15, 2001 10:47 PM
Well,let me see maybe it will flow more air. I have a " ? " for the chip burners 2. If the Pro-M is no good because of its increased flow. What will you do with the larger 2001 meter.
ShadowBolt Jan 15, 2001 10:50 PM
I know it will flow more air (smart ass)! I want to know how much power it will produce.
Jerry
Incon306 Jan 15, 2001 11:06 PM
WCFan,
The problem with the Pro-M is not that it flows more air, but the way its electronics work.
Jeff
93 Mustang GT: 11.40 @ 124.5 (old combo)
00 Lightning: 13.83 @ 99.2 (stock)
www.unlimited-racing.com
WCFan Jan 15, 2001 11:26 PM
Incon306
How does its electronics works? Do the electrons flow any different in this meter? Why do some people say that there is a problem with it? Inquiring minds what to know! What is an incon?
BulldogSVT Jan 15, 2001 11:30 PM
the new one has a larger flux capacitor!
RTKILLA Jan 15, 2001 11:45 PM
The pro-m's are very inconsistent from what I've heard from a very reliable source. The new 2001's if they can be fitted on the 99's/00's will just take better readings and be more consitent with the computer.
I hope it's out soon cause I want one.
http://www.zing.com/picture/p73d51e2...6.jpg.orig.jpg
She has allot of toys on her.
MAY BABIES STAT'S
Built 5/4/99
# 917 of 4000
Best ET. 13.42 at 100.98
best stock 13.96 at ?
2001 ET: 12.???
When the green light drops, the bullsh*t stops.
Incon306 Jan 15, 2001 11:49 PM
The Pro-M causes the CPU to lean out the truck. From what I understand since not all Pro-M's lean the truck out the same amount it causes detonation on some trucks.
Incon is a company that sells Turbo kits. I have one of thier twin turbo systems on my Mustang! (It's not running yet though https://www.f150online.com/f150board/frown.gif )
Jeff
WCFan Jan 16, 2001 12:02 AM
Thanks for the info guys.
Inconcon306
Turbos are cool. 2 are awesome.
RTKILLA
I wonder who is this source that knows all this cool stuff of what works and what does not.
whitelightnin'' Jan 16, 2001 02:32 PM
My Pro-M is in Michigan for warranty work. I had it about 6 months. It developed an erratic idle for no apparent reason except electronics. They are sending it back, hopefully this week. I ordered an extra filter and a fan shroud, mounts to 2 of the filter screws. They are very nice people...but slow to warranty....I would expect a 24 hour turnaround considering you must remove and replace an essential component.. I am interested in the 90MM Ford parta also https://www.f150online.com/f150board/biggrin.gif
SilverBullet Jan 16, 2001 04:26 PM
The mass air transfer function of the 2001 is different enough (from the 00+99) that you will require a flow sheet to use it.
Meaning they are not the same.
WCFan Jan 16, 2001 07:37 PM
What's a transfer ****ion? Can I just put the flow sheet in the glove box with my time slips. Will that work?
Burninout101 Jan 16, 2001 07:45 PM
WCFan
Hum Im not sure if that is a actual ? or another remark!
No the the parameters have to be programed in the eec. You get these from the flow sheet. I belive im correct someone correct me if im wrong tho, they usually do https://www.f150online.com/f150board/biggrin.gif
