blower bypass ???
Old Jan 6, 2001 | 01:05 PM
fastsvtss's Avatar
Banned For
Violating Vendor Rules
Post blower bypass ???
How do you disconnect the blower bypass valve on the '00 Lightning? Full explanation would be greatly appreciated. If not here then can you email the instructions to me?
thanks
Old Jan 6, 2001 | 06:53 PM
Autothrottle's Avatar
Post
On the drivers side engine, you will see the EGR (round and black) right
next to the upper intake. It has a decent size metal pipe that runs down to
the exhaust system. Halfway down, above the fuel rails, you will see a few
vacuum lines and electrical connectors. The boost bypass id the one towards
the back close to the #7 sparkplug. IT is round in shape, and has an
electrical connector that plugs in from the side facing towards the passenger
side, it will also have a couple of vacuum lines going to it.
Hope this helps
Old Jan 6, 2001 | 07:18 PM
4D THNDR's Avatar
Exclamation
It's on the driver side by the third plug back and it has 2 wires and 3 pink vacuum lines, one on top, 2 on bottom. On the side facing the front of the vehicle there is a silver sticker on it with the I.D. of XL3V-9H465. Squeeze the tab on the wire harnass and unplug it.
Red '00 Lightning,
Power Surge Performance enhanced,
Sound effects provided by Flowmaster,
375 RWHP,
445 RWTQ,
13.227@103.55
Track Videos
Old Jan 6, 2001 | 08:14 PM
Lightningquick's Avatar
Post
DONT touch the vacuum lines just the electrical connector
Old Jan 6, 2001 | 08:36 PM
Twinturbo Ranger's Avatar
Question
Hate to be a dummy on this,but are we supposed to unplug this for some reason?
00 White Lightning,R9 Superchip,Homemade induction with cone type K&N filter,Magnaflow Muffler. 93 Ford Ranger,FI 302 with 185 AFR heads,GT-40 lower intake w/Downs upper,65 mm TB,66 lb injectors controlled by Western Motorsports SDS fuel injection,TDC Stage 2 twin turbos,AOD trans w/Lentch strip valvebody,10 inch convertor and single input shaft,8.8 rearend w/mosier 31 spline axles and 3.73 gears,and plenty more !!
Old Jan 6, 2001 | 09:22 PM
Post
Twinturbo,
If you've had your boost go to ZERO about half track then you know what I'm talking about. Unplug it and that problem is history.
I ran alday yesterday with it disconnected and no problems. If you run on MT ET's then you can finally do a burnout......
