Gears
best mod you will do I gained 1+ mpg after the change .
I have 3# pulley,tune,full Bassani exhaust,cai,and gears. With
nitto's I trap at 105-107 at about 5k rpm so I still have room
in the rpm for more mods if I choose
It depends on how much modding you intend to do.
If high 12's is the most you ever expect from your truck then 4.11 might be ok but if you are serious about going fast you will find 3.73 is still not enough gear without tall tires.
I have also wanted to do this....here are a few links where it has been talked about.....this may give you some answers...
https://www.f150online.com/forums/sh...light=4.10%27s
Originally Posted by pitstain
it will kill your mileage and top end, the 3.73's are still the best all around gear.
Funny that. I gained mpg when I switched. Of course, I'm running on 22's. I've heard a couple of others say that they gained mpg as well. It depends on where you do most of your driving really. Around town or freeway.
22's plus a 4.10 gear and youre basically back at 3.73 if not less.....what is your tire size ?
I MUST disagree with some of the posts here.
I LOVED the 4.10's and gas mileage went up in city driving.
Here I did the hard work for you:
https://www.f150online.com/forums/sh...ighlight=gears
and
and
and
That should answer ALL your questions.
and
and
and
