P0068 trouble code?
P0068 trouble code?
Anyone know what this would refer to? I looked it up in my scanner manual and cannot find it. Everything on the 'net I find about OBD-II codes doesn't show anything below P0100.
Truck runs perfectly fine, but the MIL just came on today.
Any help would be much appreciated.
Thanks!
Thanks!
P0068 - Throttle Position (TP) Sensor Inconsistent with MAF Sensor
The PCM monitors a vehicle operation rationality check by comparing sensed throttle position to mass air flow readings. If during key ON engine running self-test the comparison of the TP sensor and MAF sensor readings are not consistent with calibrated load values, the test fails and a diagnostic trouble code is stored in continuous memory.
- Air leak between MAF sensor and throttle body
- TP sensor not seated properly
- Damaged TP sensor
- Damaged MAF sensor
- Damaged TP sensor
Thanks, Sal!! Must be something with the SCTMAF and Accufab TB. What's weird is that I've had this combo on the truck for 4 months without any issue. The only thing that has changed recently is the cold temps we have now in N. Texas.
