Having problem with my 99 L
Try looking for a thread or two dealing with fuel pump connections. It was a while back, but someone had similar problems with fuel delivery and it was split/cracked or loose fuel pump connections. I have no idea if that would affect boost and I don't remember that being mentioned, but it may have something to do with the fuel delivery as well.
Good Luck
Bill
99.5 Lightning
Build #247
PSP Chip/Filter
Bassani full system
White/normal options
Tamiya 1/10 scale Bolt
Several old trucks/cars
Thunder & Lightning
Rag Doll Cats
E-mail MOSTOYSINC@AOL.com
Kennesaw, Ga. (Atlanta)
Good Luck
Bill
99.5 Lightning
Build #247
PSP Chip/Filter
Bassani full system
Thunder & Lightning
Rag Doll Cats
Hi Flash
Hi Bill
Bill is right have them check fuel presure, and fuel volume. Boost can be temp related. My owen truck on hot day(93+), the gauge would only show 8lb, and with lower temp hit 10lb. But now with PSP filter and a chip, is going past 10, looks like 12-13lb. But back to temp, less O2 in air the higher temp goes. In the winter I bet my truck stock got 10-20hp more.
99.5 Black Lighting
Superchip,PSP AIR FILTER,PSP Chip,CD Changer,Tow Pack,Ford Bed Liner,2In Drop Shackles,Tinted Windows,4 Rear Stoplights,339HP 410FTLB at rear tires
2000 Mustang GT
Convertible,Performance Red,Black Top,5 Speed,
Cobra R Wheels,BFG Tires,Bassani X Pipe, Flowmaster Mufflers / Stock tips,K+N Filter With Air Silencer Removed,FMS 4.10 gears,FMS King Cobra Clutch,235HP 276FTLB at rear tires
99 Triumph Speed Triple
955cc,Roulette Green,Corbin Seat,Carbon Fiber Silencer,Fry Screen,Carbin Fiber Tank Pad
Hi Bill
99.5 Black Lighting
2000 Mustang GT
I have a 99 L and im having problems with it. When I go to start it up, you have to keep turning the key to start it. It acts like it is not getting enough fuel or that it is flooding when I turn it off. Any suggestions on what it might be. The only thing I have done with my truck it K&N air filter and flowmaster. I also have a problem with not not geting the same amout of boost that I use to get. It starts out at 8 lbs when i stomped and go past the 10 mark buy the time I was geting ready to shift into 3rd gear and now im lucky to get 6lbs when i stomp on it and go up to 8 lbs at the end of 3rd gear. I know that the factory boost guage is not that accurate but its not running the same as what it use to. I would appreciate your input on what this might be. Thanks in advance.
