Powering problem for Gauges
Old Nov 11, 2006 | 03:00 PM
Lstrike03's Avatar
So I have my gauges installed and they have power to them. I used an idea from one of the other guys and tapped (using a fuse tap) into the specified location http://www.timskelton.com//lightning.../gauge_pod.htm
Now when I start it the gauge goes all the way to the right. What's up?
Old Nov 11, 2006 | 04:16 PM
04LIGHTING's Avatar
I'm doing the same project now, autometer autolite gauges boost ( mech, and a/f/gauge). if i figure it out ill let u know, if i cant figure it out. im just gonna go and get it installed.
Old Nov 13, 2006 | 11:18 AM
Lstrike03's Avatar
anyone have a fix?
Old Nov 13, 2006 | 07:56 PM
SWThomas's Avatar
Sounds like a ground issue to me. Where did you put the ground for the gauge?
Old Nov 14, 2006 | 02:23 AM
Lstrike03's Avatar
I grounded it to the frame behind the pillar.
Old Nov 14, 2006 | 01:45 PM
LTNDave's Avatar
sounds like you may have hooked up the signal wire a constant +12 volts
Old Nov 14, 2006 | 02:53 PM
Lstrike03's Avatar
Angry
Everything is hooked up fine. It's grounded, the power is not constant (I tried that on purpose). It's all good until I turn the truck over, then the thing just pegs itself out. I can't figure it out at all. I'm talking to the guys at autometer to try and figure it out. Thanks for the ideas guys, keep them coming, I'll keep trying everything until I get this to work.
Old Nov 15, 2006 | 01:13 PM
LTNDave's Avatar
what gauge is it?
Old Nov 16, 2006 | 10:23 AM
Lstrike03's Avatar
It's the Boost Gauge
Old Nov 16, 2006 | 11:57 AM
Don's Bolt's Avatar
It looks like tim uses the same fuse I am using, but his picture is a little confusing.
Here is where the power to my Boost guage is hooked up
Old Nov 16, 2006 | 01:42 PM
TampaBlack99's Avatar
Buy a external fuse box and stop hacking up the oem wires.
Old Nov 16, 2006 | 02:16 PM
Lstrike03's Avatar
Mine is hooked up exactly how you have it in the picture. I tried the external fuse as well and resulted in the same results.
