Grinding front calipers
Ok guys, I have used the search button but did not find very much info. Does anyone have a how-to or even some pictures for grinding down the front caliper. I have found alot on the rear but not that much for the front. I am fitting 15" bogarts up front.
Any info on how much to grind down would be greatly appreciated |
Basically you will see some casting ribs on them. You just have to grind them off; not near as much as the rears.
That is about it, and you will need some wheel spacers. |
I've got 15x5 Drag Star's and it was just grind the casting ridges down a little bit and they fit right on perfect. |
