Who's removed their Pass Seat by themselves???
Is it a two man job only, or can you wrestle it out yourself?
Thanks...... Joel |
Re: Who's removed their Pass Seat by themselves???
Originally posted by JoeLightning Is it a two man job only, or can you wrestle it out yourself? Thanks...... Joel I would go for 2 people if I had that option .... |
My 180 pound self has done it a couple of times. Not that bad; just gotta be ready and fold it down helps.
Cool, Thanks Doug and Casey!
It weighs about 70-75 pounds.
Where can I get the tool needed to remove it?
Thanks, Jello |
any tool store, its a torx-bit
It is a bear! And be carefull when going through the door opening. It's really easy to drag one of the feet against the paint or door panel.
Rich |
I did it and im a little guy.
i have done it a couple times myself, but i fell much more comfortable doing it with some help. i would hate to scratch the truck or door panel
I did it myself too... It was a bit awkward by myself tho. If I had to do it again, I'd get help.
It helps a bit to pull your floor mat over so it hangs out of the door a little. Helps to keep from scratching things up.
Jason |
A torx bit from NAPA for like 6 dollars. It is easy to remove.The toughest thing is getting the seat belts out....I have thought about leaving it out.But I know as soon as I do that I will have a friend need a ride somewhere or something will happen that will make me put the seat back in...
Originally posted by StruckBy99 It helps a bit to pull your floor mat over so it hangs out of the door a little. Helps to keep from scratching things up. Jason and the seat isn't to hard to get out.... its just bulky.......:) |
GET SOME HELP.
I screwed my back up removing mine. I now have the bucket seet mod. It is much lighter and easier to remove. You need a 55 torx bit to remove it.:rocker: |
| All times are GMT -4. The time now is 03:44 AM. |
