11's
Old Mar 23, 2005 | 04:48 PM
Blown93's Avatar
11's
Has anyone ever hit the 11's with 6 lbs of boost over stock, with out a converter, nitrous or aftermarket blower or heads.
PEacE........................
Old Mar 23, 2005 | 05:01 PM
zx12guy's Avatar
I came across this today when searching info on ds loops.
https://www.f150online.com/forums/sh...riveshaft+loop
Old Mar 23, 2005 | 05:47 PM
Derek94's Avatar
I know that i hope to be in the general viscinity whenever i get a dyno tune and go out to the track. What other mods do you have other than whats in your sig. Anything?
I have:
Apten
4lb
CAI
CL Plenum
SBTB
Kooks longtubes, high flows
ftvb
traction bars/28inch hoosiers...
I'm hoping that this will get me close to my goal..
also, blown93 will you be at cecil for the SSOTN? I need to get my money in for that event.
Old Mar 23, 2005 | 05:49 PM
bluballz's Avatar
I did manage to run quite a few 11 sec passes with a 6# no juice,now aftermarket blower,or converter.When i ran my first 11 sec passes i had a chip,filter,full length exhaust,6#,throttle body,heat exchanger,and slicks.With that set up i did run a best time of an 11.87.
mike
02 true blue 11.67@115
JDM Enhanced
sct chip,filter,full lenghth exhaust,6#,throttle body,converter,
heat exchanger,e-fan,cobra r pump,traction bars,qa 1 shocks(rear),and slicks/drag radials(time above on drag radial)
stock long block and stock eaton 54,000 miles(knock on wood)
Old Mar 23, 2005 | 06:27 PM
Blown93's Avatar
Derek94
I will be at Cecil. And those are my mods...........
Mike your flying. The Blue color doesn't hurt either........
PEacE..............................
Old Mar 23, 2005 | 07:12 PM
bad00's Avatar
mike
JDM Enhanced
Your truck dose run good!!!
I have converter and juice and can only get 12.0X's out of my truck!!!
Old Mar 23, 2005 | 07:58 PM
Fast Gator's Avatar
Are you forgetting about me 11.90 all the time,stock convertor, stock long block, stock blower, then I went to a Apten Port Job
Now, I got the goods..........
Old Mar 23, 2005 | 08:39 PM
chief40al's Avatar
11.87 stock blower,6lb lower, no converter
Better times to come!
Old Mar 23, 2005 | 08:44 PM
Blown93's Avatar
Johnny said he could get me 25 hp more from my tune if I use race fuel, Maybe I will make a run at you guys this fall. Does the modding or thrist to go faster ever stop... I have only 3 passes on my truck with the current mods............
Old Mar 23, 2005 | 10:50 PM
bluballz's Avatar
Bad 00....what kind of 60' times are you getting,and what other mods do you have?
mike
Old Mar 23, 2005 | 10:56 PM
Derek94's Avatar
Hey chief40al could you list your mods? 60ft also
Old Mar 23, 2005 | 11:54 PM
chief40al's Avatar
My best 60 was 1.62
Mods
C&L Plenum
JDM Phenoic Spacers
JDM Elect. fan
Cobra water pump
JDM Long tube headers
JDM/Magnaflow exhaust
6lb lower
JDM 58" bars
SCT Tuner
Powercooler
Cervines Cowl Hood
Bucket seat Mod
Lund Roll Pan
16" Hoosier Slicks
16' Front skinnies
JDM Dyno Tune
446.02 RWHP
569.54 Torque
Old Mar 24, 2005 | 01:54 AM
bad00's Avatar
mike
60' times are mid to low 1.6's. full exhaust, 4lb lower, 2.8 rr upper,SBTB,2600 PI Stahl, super cooler, caltrak's, 28" qtp's, zex wet kit.
Chief40al What was your 1/8 mile times on your 11.87 run????
Old Mar 24, 2005 | 08:34 AM
chief40al's Avatar
60' 1.70
330 4.921
1/8 7.59
mph 91.77
1000 9.905
1/4 11.872
mph 114.44
Old Mar 24, 2005 | 11:18 AM
Derek94's Avatar
Hey blown93 what numbers are you putting out right now? I havent been dyno tuned yet, but i plan on it shortly. I hope to go up to JL's and have it done.
