Lunar gauges flickering?
I just installed my Lunar boost gauge, hooked up the power to the factory dimmer switch. When it's not at full power, it flickers, and when I dial down the dimmer towards the very low end, it's not powered at all.
Does anyone else have these issues? I checked all of my wiring and it doesn't seem to be a loose connection. Or is it just a problem with the factory dimmer? Thanks |
Mine do the same.. I don't ever dim my dash lights anyway, so it doesn't bother me.
I used a resistor to dim the Lunar gauge to make it look sorta like the factory gauges. :wave: |
Originally posted by clonetek I used a resistor to dim the Lunar gauge to make it look sorta like the factory gauges. |
I just doubled up the leads & crimped them inline on the power wire using butt splices. Then I covered the whole thing up with shrink tubing. :)
